Old 10-06-2011, 11:49   #1 (permalink)
farouk04's Avatar
Member: 192302
Sonork: 100.1606958
Thanks Meter: 62
how to flash c3322 with z3x please
are there any way to flash c3322 via z3x please !!!!
The Following 2 Users Say Thank You to farouk04 For This Useful Post:
Old 10-06-2011, 11:50   #2 (permalink)
.::VijayAnand::.'s Avatar
Member: 740523
Thanks Meter: 89
iam also same problem/////////////////
Old 10-06-2011, 12:31   #3 (permalink)
unuunu's Avatar
Member: 1623262
Sonork: 100.1621312
Thanks Meter: 95
i tried for 6 days to connect c3222 with z3x but not success .........i dont understand how can i flash or unlock the phone?is it usb driver problem or what?i am going to be mad......if my problem will be solved in 2 days i will throw the box......
The Following 2 Users Say Thank You to unuunu For This Useful Post:
Old 10-06-2011, 12:37   #4 (permalink)
NKhan_Gsm's Avatar
Member: 1646177
Sonork: 100.1604654
Thanks Meter: 334
Mate its flashing is not supported flash with its Flasher:
http://www.fileserve.com/file/vHjrfU..._v0.1_Lite.rar
WBR
The Following 2 Users Say Thank You to NKhan_Gsm For This Useful Post:
Old 10-06-2011, 12:41   #5 (permalink)
unuunu's Avatar
Member: 1623262
Sonork: 100.1621312
Thanks Meter: 95
i even cant read info brother..................
Old 10-06-2011, 12:57   #6 (permalink)
NKhan_Gsm's Avatar
Member: 1646177
Sonork: 100.1604654
Thanks Meter: 334
Here is the Manual how to Flash :
1- First you have to install USB drivers by click on Setup.exe inside this Folder: Sunstone_V5_00_0_1_WHQLed
2- Power on the phone and connect USB cable to it and to PC to let Windows install its drivers.
3- Turn off the phone and connect USB cable to it and to PC to let Windows install its drivers.
4- Run the C3322 Flasher: Flash loader 7.4.7_SSG_v0.1_Lite.exe
5- Click SET MODEL button and select: C3322_LAKOTA_Setting_v00.mdl
6- For Application Binary File select:C3322xx.ptt
7- For Tfs file select: C3322xxxxx.tfs
8- For CSC file select:C3322xxxxx.csc
9- Turn off the phone and connect USB to it while pressing Q + A keys to install DFU mode drivers.
10- Disconnect the phone after DFU drivers installed.
11- Click START button and reconnect USB cable to phone while pressing Q + A keys.
12- The program will detect it and start the Update Process so wait till all is DONE.
13- Disconnect the phone and turn it on then do Full reset: *2767*3855#
WBR
The Following User Says Thank You to NKhan_Gsm For This Useful Post:
Old 10-06-2011, 13:08   #7 (permalink)
NKhan_Gsm's Avatar
Member: 1646177
Sonork: 100.1604654
Thanks Meter: 334
Mate use Micro URT Cable(C3303K RJ45 cable) connect phone with battery and press power or change to Flash mode from Setting model and use USB cable but first you have install drivers and click on Read INFO than Press "volume down" + "lock" and connect USB cable to phone.
WBR
Old 10-06-2011, 13:12   #8 (permalink)
unuunu's Avatar
Member: 1623262
Sonork: 100.1621312
Thanks Meter: 95
u mean i have to use two cable?
Old 10-06-2011, 14:03   #9 (permalink)
farouk04's Avatar
Member: 192302
Sonork: 100.1606958
Thanks Meter: 62
where is volume down in this phone !!!?????
Old 10-06-2011, 14:06   #10 (permalink)
NKhan_Gsm's Avatar
Member: 1646177
Sonork: 100.1604654
Thanks Meter: 334
No everyone is available for you you can use
Old 10-06-2011, 14:37   #11 (permalink)
farouk04's Avatar
Member: 192302
Sonork: 100.1606958
Thanks Meter: 62
i made big mistake---i flashed the phone via ufs so the pc cant recognised the phone how can i revive it ....
Old 10-07-2011, 04:11   #12 (permalink)
NKhan_Gsm's Avatar
Member: 1646177
Sonork: 100.1604654
Thanks Meter: 334
Mate Charge your phone battery and try according above manual in Post NO.6.
WBR
Old 10-07-2011, 05:37   #13 (permalink)
unuunu's Avatar
Member: 1623262
Sonork: 100.1621312
Thanks Meter: 95
Still then i am not clear how to read info from c3222 using z3x.......
Old 10-07-2011, 07:26   #14 (permalink)
NKhan_Gsm's Avatar
Member: 1646177
Sonork: 100.1604654
Thanks Meter: 334
Mate try this :
Click on Read Info and connect USB cable to phone while pressing Q + A keys.
WBR
Old 10-07-2011, 07:37   #15 (permalink)
unuunu's Avatar
Member: 1623262
Sonork: 100.1621312
Thanks Meter: 95
what a joke???????????//evry time i asked about the problem i am getting new way to press keys......i am confused that actually which keys i have to press?have u ever done this solution or not?
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Page generated in 0.39849 seconds with 9 queries
