02-09-2009, 17:54 | #1 (permalink) |
No Life Poster Join Date: Aug 2008 Location: Prizren
Member: 841080 Status: Offline Thanks Meter: 177 | How to flash lg ku385, urgent???? v.1.3.0 supported models: 51 andrew_tm 2008(c) Select ComPort or use Search Phone button! Elapsed: 0 secs. Reading file as KU385... Ok Patch Flash File: KU385-V10a-DEC-19-2007-P4P+1 Lang(ver 1.0): -French=Russian -Italian=Ukrainian Reading timeout, check cable Error Code: ReadInfo,1,1 Elapsed: 2 secs. how to flash urgent is..... |
02-09-2009, 20:22 | #2 (permalink) |
Product Supporter Join Date: Feb 2007 Location: Europe
Member: 445973 Status: Offline Thanks Meter: 3,489 | 1. Press 2+5+power 2. Press "Search phone" 3. Select firmware 4. Press "Flash" 5. After flash write default nvm ( KU385_network_ok.cnv from support or ~c:\programm files\z3x\lg\lgq\nvm). -- andrew_tm 2009. |
The Following 2 Users Say Thank You to andrew_tm For This Useful Post: |
02-11-2009, 06:18 | #6 (permalink) |
No Life Poster Join Date: Aug 2006 Location: On Earth
Member: 332724 Status: Offline Sonork: 100.1605077 Thanks Meter: 231 | Hai friend!It may be change your country code. hai friend! I think change your country code your problem may be solved.By using repair button.Bai. |
02-11-2009, 23:08 | #9 (permalink) |
Member: 841080 Status: Offline Thanks Meter: 177 | problem solved after flash 5 times with 5 different flash file from support , thnx........... |
The Following User Says Thank You to svchost For This Useful Post: |
How to flash SGH B520.-URGENT- | prashantvrm | Samsung Flashers, Software, Firmware. | 1 | 03-29-2010 13:24 |
Pleeeeeeeease How To Flash Lg W7000 | MindPower | LG | 3 | 07-02-2009 06:49 |
How to flash lg ku385? | Tahir Riaz | Infinity-Box | 2 | 11-14-2008 05:26 |
How to Flash v3 help urgent | master10 | Motorola P2k | 1 | 10-29-2007 01:28 |
Please Guy How To Flash Lg W7000 | MindPower | LG | 0 | 07-16-2004 22:21 |
