01-18-2019, 14:40 | #1 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Here Age: 47
Member: 175183 Status: Offline Sonork: 0 Thanks Meter: 120 | How to flash P585M with FRP LOCK ? I get tablet with Custom Binary(BOOT) Blocked by FRP LOCk Try to flash COMBINATION_ZTO_FA60_P585MUBU1AQC2_ZTOFAC_CL888227 4_QB13032847_REV00_user_mid_noship.tar.md5 and get error. Code: FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-P585M Software version: 34.8 File analysis... OK Total file size: 0x476D8158 (1142 Mb) Searching USB Flash interface... COM7 detected Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending param.bin... OK Sending cm.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... error timeout Done with Samsung Tool PRO v.34.8 Code: FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-P585M Software version: 34.8 File analysis... OK Total file size: 0xD5C50550 (3420 Mb) Searching USB Flash interface... COM7 detected Setup connection... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending param.bin... OK Sending cm.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... error timeout Done with Samsung Tool PRO v.34.8 |
01-18-2019, 21:55 | #3 (permalink) |
Freak Poster Join Date: Jun 2016 Location: jordan
Member: 2588864 Status: Offline Thanks Meter: 62 | You have to check security level on your phone...this error obtained when try to flash lower security level may be phone U2 so go to recovery mode to determine firmware of phone so can flash proper without any problem |
01-19-2019, 14:28 | #4 (permalink) |
Member: 175183 Status: Offline Sonork: 0 Thanks Meter: 120 | Hi. Only have binary 1 for this tablet. All firmware have B1. Now I flashed ok with combination file, and enter in factory binary. But cant reset FRP, any trick to reset FRP? |
01-20-2019, 00:14 | #5 (permalink) |
Member: 2588864 Status: Offline Thanks Meter: 62 | i think oem still hidden even you flash combination, now you may try flash full official flash without userdata after finish flash phone should open menue go to setting and enable developer then make oem on hard reset and FRP off....goodluck |
