07-15-2017, 18:20 | #1 (permalink) |
No Life Poster Join Date: Mar 2015 Location: kapurthala punjab
Member: 2362867 Status: Offline Sonork: ththtuu Thanks Meter: 659 | How to get msl code sm-g950f Unlocking with original MSL code: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will apear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Unlock Selected model: SM-A520F Software version: 28.7 Searching Samsung modem... detected COM43 Reading phone info... OK Model: SM-G950F AP version: G950FXXU1AQDG CSC version: G950FEVR1AQDG CP version: G950FXXU1AQDG Product code: EVR Phone SN: RF8J413VSZV Unique number: CE0317132B1448210C Reading IMEI... OK IMEI: 355089088997550 Reading SN... OK Phone SN: RF8J413VSZ Enter MSL: canceled Operation aborted Done with Samsung Tool PRO v.28.7 |
The Following User Says Thank You to sachu2002 For This Useful Post: |
07-15-2017, 19:08 | #3 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | To get MSL codes reliably and quickly, check with the user of this forum mr_basel_99 http://forum.gsmhosting.com/vbb/member.php?u=2109940 |
