08-21-2012, 15:12 | #1 (permalink) |
Freak Poster Join Date: Oct 2010 Location: india
Member: 1417201 Status: Offline Sonork: 100.1626868 Thanks Meter: 32 | how to hard reset s6500 samsung galaxy mini 2 |
08-21-2012, 16:58 | #2 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Algeria
Member: 695274 Status: Offline Thanks Meter: 814 | for download mode: volume up + volume down +home and press power and for reset: Samsung GT-S6500 Galaxy mini 2 hard reset Turn off S6500. Press and hold POWER + ENTER button for reset menu. Select Factory reset with Volume Down button and press Power to reset. All data will be lost! or Use this method to hard reset your Samsung GT-S6500 Galaxy mini 2 phone: Enter *2767*3855#. Warning! All your data including contacts, messages etc. will be lost! Copy all your necessary data/Contacts/Messages etc. to SIM or make backup to your PC before full reset! Take out SIM card before full reset. Samsung GT-S6500 Galaxy mini 2 download mode if you want to install eg. Gingerbread Press and hold Volume DOWN + HOME + POWER ON S6500 Restart your device to clear any temporary software bugs Your device freezes or has fatal errors If your device freezes or hangs, you may need to close programs or reset the device to regain functionality. If your device is frozen and unresponsive, press and hold [Power] for 8-10 seconds. The device will reboot automatically. If this does not solve the problem, perform a factory data reset. In Idle mode, open the application list and select Settings → Privacy → Factory data reset → Reset phone → Erase everything. Clear storage • : Erase the credential contents from the device and reset the password Set an unlock pattern Once you set a screen lock, your device will require an unlock code each time you turn it on or unlock the touch screen Settings → Location and security → Set screen lock → Pattern If you forget your PIN or password, bring your • device to a Samsung Service Centre to reset it. Set an unlock PIN code Settings → Location and security → Set screen lock → PIN Set an unlock password Settings → Location and security → Set screen lock → Password. You can hard reset software firmware update your Samsung GT-S6500 Galaxy mini 2 phone: Connect with Samsung Kies S6500 firmware upgrade Android. You need this key combination if you are going to upgrade your S6500 android firmware. Press and hold Volume DOWN + HOME + POWER ON S6500 This is NOT the hard reset. See reset procedure above. |
10-24-2013, 04:35 | #4 (permalink) |
Product Manager Join Date: Dec 2009 Location: CEO.of.ROMDevelopers Age: 32
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,979 | Yes Mr Nadoui Right But If Phone Hang On Logo Or Restarting Hard Reset Mode Not Come At This Moment You Need Flash Br, AzimBahar |
