05-07-2016, 06:38 | #1 (permalink) |
Freak Poster Join Date: Jan 2010
Member: 1206133 Status: Offline Thanks Meter: 8 | How to repair this error in z3x mtk smart tool DBI Err Fatal! DemiGod Crash Handler : DBI ERR Fatal! Board Rev.:1.0 Ram dump mode. Option : SD card ram dump mode Push below files to sdcard before test. rdcookie.txt ,rtcookie.txt Please do following action. 1)Ram dump Mode. Please connect USB. 2) Get the ram dump image using QPST Configuration. 3) If sdcard ram dump enabled just wait for reboot. 4)Collect ramdump files from your pc or sdcard. 5)Send e-mail to [email protected] The same problem was solved in the following link,But no procedure http://forum.gsmhosting.com/vbb/f779...ix-ok-2055801/ How to repair with step by step instruction in z3x mtk smart tool Thanking you |
05-07-2016, 07:55 | #2 (permalink) |
Member: 1206133 Status: Offline Thanks Meter: 8 | I tried with tset point but gives following error Selected model is:LG D380 Connect powered off QC Device to USB cable... You have 10 seconds... Detected HS-USB instance: COM40 , Qualcomm HS-USB QDLoader 9008 (COM40) Connect OK Using COMPORT: 40 Connecting to target... QFastDL Ping Success... Sending Loader... Waiting for Loader... Detected APRG instance: COM40 , Qualcomm HS-USB QDLoader 9008 (COM40) Connect OK Configuring protocol on COM40OK Loader mode are EMMC. Set security mode off... OK Opening multi image transfer mode... Timeout! Downloading image FAILED Connect powered off QC Device to USB cable... You have 10 seconds... Detected HS-USB instance: COM40 , Qualcomm HS-USB QDLoader 9008 (COM40) Connect OK Using COMPORT: 40 Connecting to target... QFastDL Ping Success... Sending Loader... Waiting for Loader... Detected APRG instance: COM40 , Qualcomm HS-USB QDLoader 9008 (COM40) Connect OK Configuring protocol on COM40OK Loader mode are EMMC. Set security mode off... OK Opening multi image transfer mode... Timeout! Downloading image FAILED Connect powered off QC Device to USB cable... You have 10 seconds... Detected HS-USB instance: COM40 , Qualcomm HS-USB QDLoader 9008 (COM40) Connect OK Using COMPORT: 40 Connecting to target... QFastDL Ping Success... Sending Loader... Waiting for Loader... Detected APRG instance: COM40 , Qualcomm HS-USB QDLoader 9008 (COM40) Connect OK Configuring protocol on COM40OK Loader mode are EMMC. Set security mode off... OK Opening multi image transfer mode... Timeout! Downloading image FAILED Connect powered off QC Device to USB cable... You have 10 seconds... Detected HS-USB instance: COM40 , Qualcomm HS-USB QDLoader 9008 (COM40) Connect OK Using COMPORT: 40 Connecting to target... QFastDL Ping Success... Sending Loader... Waiting for Loader... Detected APRG instance: COM40 , Qualcomm HS-USB QDLoader 9008 (COM40) Connect OK Configuring protocol on COM40OK Loader mode are EMMC. Set security mode off... OK Opening multi image transfer mode... Timeout! Downloading image FAILED |
