01-25-2010, 05:59 | #1 (permalink) |
Freak Poster Join Date: Dec 2008 Location: Davao City, Philippines
Member: 935609 Status: Offline Thanks Meter: 154 | How to repair Imei for samsung jet S8000/S8003 via usb cable then follow sequence sequence below *#197328640# 8 Common 5 Usb Configuration 2 USB ACM -CP USB ACM - CP COnfigured press end call and turn main menu again *#197328640# 8 Common 6 UART Configuration 1 DIAG Diag SRVC Configured press end call and turn main menu again *#197328640# 8 Common 7 Service Configuration 2 DIAG Service 2 USB DM/CP USB ACM/CP Configured Now Connect usb then repair imei Enjoy |
The Following 24 Users Say Thank You to right_click For This Useful Post: |
02-22-2010, 00:22 | #4 (permalink) |
No Life Poster Join Date: Apr 2003 Location: United kingdom Age: 64
Member: 26440 Status: Offline Thanks Meter: 6 | The above info is wrong. whilst z3x box can change imei . when u restart the s8000 it goes back to original. i have tried and tested the above method. does not work |
02-22-2010, 09:11 | #5 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,554 | Quote:
ONLY AFTER START WRITE SOMETHING IN FORUM. first need write patch file. only after can imei repair. IF not use patch after phone restart imei go back to original. | |
02-22-2010, 12:53 | #7 (permalink) | |
Member: 935609 Status: Offline Thanks Meter: 154 | Quote:
03-27-2010, 16:34 | #9 (permalink) | |
Freak Poster Join Date: Jan 2006
Member: 222412 Status: Offline Thanks Meter: 9 | Quote:
spitroast | |
03-31-2010, 19:38 | #11 (permalink) |
No Life Poster Join Date: Aug 2008 Location: brazil Age: 47
Member: 846805 Status: Offline Sonork: alex cavalcante Thanks Meter: 261 | Procedure perfect, but when you remove the battery it back to the original imei How should I get the imei I want ..? Searching Qualcomm USB interface... detected (COM79) IMEI: 356174030158418 Repairing as MSL3... ok (IMEI - 357381030695558)! (time - 00:00:00) Searching Qualcomm USB interface... detected (COM79) IMEI: 357381030695558 |
03-31-2010, 19:53 | #12 (permalink) | |
04-01-2010, 08:43 | #15 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: ---------->>Gsm City
Member: 489622 Status: Offline Thanks Meter: 435 | Quote:
im trying to flash patch file but this error model s8003 Code: Searching Samsung USB Flash interface... detected (COM12) Sending file 1 of 5... sended Sending file 2 of 5... sended Sending file 3 of 5... Error (Boot mismatch) | |
how to repair imei of samsung i450 | kripalu | Samsung Flashers, Software, Firmware. | 4 | 04-25-2010 10:23 |
how to repair imei for pantech c120 ?:::ANSWERED::: | yorel2202 | PolarBox 3 | 4 | 04-09-2009 18:47 |
How to repair imei of samsung E250 | Sahil2007 | UST Pro II | 3 | 08-26-2008 17:51 |
How to Repair IMEI for Sendo S360 | D-Master | Multi-Box | 4 | 03-16-2007 13:32 |
