Old 04-01-2010, 10:03   #16 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 177,856
Originally Posted by yasin_telecom View Post
im trying to flash patch file but this error model s8003
Searching Samsung USB Flash interface...  detected (COM12)
Sending file 1 of 5... sended
Sending file 2 of 5... sended
Sending file 3 of 5... Error (Boot mismatch)
Boot mismatch - flash same boot file via multiloader.
all files on support.
be carefull with boot flashing.
Old 04-01-2010, 10:03   #17 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Originally Posted by jakoy View Post
maybe bugz for this update...
no any bug if you have 2 right hands.
Old 04-01-2010, 10:09   #18 (permalink)
jakoy's Avatar
Member: 14852
Sonork: 100.1608716
Thanks Meter: 500
here the logs but the phone i already give it to the customer...
READ NEWS FOR DETAILS!
Reading file as S8003... ok
Model: S8003
Version: S8003JVIF1
Searching Samsung USB Flash interface... detected (COM304)
Sending file 3 of 5... sended
Sending file 4 of 5... sended
Sending last file... sended
Flashing done (time - 00:05:47)
Searching Samsung USB interface... detected (COM304)
Checking mobile state... normal
Model: S8003
SW: S8003JVIF1
IMEI: 357381030342813
Unlock as MSL3... error flash patched firmware first
Model: S8003
SW: S8003JVIF1
Model: S8003
Version: S8003JVIF1
Info: Patched for unlock v2
Flashing done (time - 00:06:13)
Searching Qualcomm USB interface... detected (COM305)
Sending last file... bad answer
Reading file as S8000... ok
Model: S8000
Version: S8000XEIG2
Flashing done (time - 00:08:30)
Searching Samsung USB interface... not found
USB interface required
Checking mobile state... flash
i have try also flash S8000
Model: S8000
Version: S8000XEIG2
Old 04-01-2010, 10:27   #19 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
why you try unlock phone from flash mode.
read manual: there power on phone, connect cables, press unlock or imei reapir.
Old 04-01-2010, 10:42   #20 (permalink)
jakoy's Avatar
Member: 14852
Sonork: 100.1608716
Thanks Meter: 500
yes i try all the possibility solution but not success for me...
i don't no if i have wrong to my procedure...
Old 04-01-2010, 10:44   #21 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
only 1 possibility exist:
flash patch flash , power on phone , press direc unlock/imei repair.
from your log i not see this steps.
i saw only: power on phone, unlock, (patch missing, just flashed normal fw.)
Model: S8003
Version: S8003JVIF1
Model: S8003
SW: S8003JVIF1
and 2 times i saw: patch flash. unlock (power on phone missing, so you have error - phone in flash mode.)
Model: S8000
Version: S8000XEIG2
The Following User Says Thank You to blang For This Useful Post:
Old 04-07-2010, 12:54   #22 (permalink)
Member: 1183902
Thanks Meter: 14
Originally Posted by blang View Post
1. flash patch flash.
2. imeir repair.
3. power off phone.
4. switch on phone, check imei.
imei changed but phone is still not working with blocked network
Old 04-07-2010, 13:16   #23 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
not undertstand nothing. !!!
Please not post in existed tread new problem!!!
If you have any problem - open new thread with name of problem in tread name and wait for help.
Old 04-20-2010, 11:43   #24 (permalink)
Crazy Poster
Member: 228551
Thanks Meter: 3
Please can you tell me which patch file i need to flash with?
Thanks
Old 04-28-2010, 09:27   #25 (permalink)
Member: 161523
Thanks Meter: 2
anyone can help me how to repair imei og GT-S3653w...
log
Selected model: S3653
Selected com port: COM3
Selected speed port: 921600
Phone must be ON
Search modem ... OK
Search modem on:COM4
Phone OLD IMEI: 00000000000000 /0
Phone SW: S3653WDXJA2
Init SWAP - ok
Detecting UART port..... OK
Wait for boot ...
Reconnect cable on phone for init modem
Search modem ... OK
MSL DEACTIVATED - FALSE
Elapsed time: 51 second, sw ver: 3.4.0040
Old 10-27-2010, 08:09   #26 (permalink)
scorpion_bashee's Avatar
Member: 334773
Thanks Meter: 91
USE SEARCH BUTTON AND READ MANUAL HOW IMEI REPAIR.
ONLY AFTER START WRITE SOMETHING IN FORUM.
first need write patch file. only after can imei repair.
IF not use patch after phone restart imei go back to original.
any pactch file we can flash it sir or we want to match it for firmware .like
S8000XEIG1,S8000BVJIG3.
Old 11-01-2010, 18:52   #27 (permalink)
Member: 1158775
Thanks Meter: 4
s8000
Model: GT-S8000
CountryCode: XEU
Factory SW: XXIF5_OXAIF3
UniqueNumber: 74240001132683
MemoryPhone: KAC00F008M(S8000)
IMEI: 35179200818174/2
Phone S/N: RVQA889999
Build: M6246AKPUOL120026_3G_02
Reading old IMEI... OK (351792008181742)
Repairing IMEI... OK
New IMEI: 352513003774334
ı need help pro ıs rapaır ımeıl and not rebıild imeil help mee
Old 12-02-2010, 17:21   #28 (permalink)
Alexandro Monte's Avatar
Member: 846805
Sonork: alex cavalcante
Thanks Meter: 261
Model: GT-S8000B
CountryCode: ZTO
Factory SW: VJIH1
UniqueNumber: 74700000258242
IMEI: 35617403061183/7
Phone S/N: RS6Z104014
Reading old IMEI... OK (356174030611837)
New IMEI: 356174030611886
Done with Samsung 3G tool ver 8.8
Not imei repair
Old 01-17-2011, 14:36   #29 (permalink)
Member: 472482
Thanks Meter: 100
After i flash it with patch file,i repair the imei, i can flash it again with diferent file? with else firmware? The imei back again the original?
Old 02-19-2011, 11:18   #30 (permalink)
gsmcare1's Avatar
Member: 728839
Thanks Meter: 26
Thank's Bro Nice job
how to repair imei of samsung i450 kripalu Samsung Flashers, Software, Firmware. 4 04-25-2010 10:23
how to repair imei for pantech c120 ?:::ANSWERED::: yorel2202 PolarBox 3 4 04-09-2009 18:47
How to repair imei of samsung E250 Sahil2007 UST Pro II 3 08-26-2008 17:51
How to Repair IMEI for Sendo S360 D-Master Multi-Box 4 03-16-2007 13:32
Page generated in 0.45404 seconds with 8 queries
