10-23-2014, 15:38 | #1 (permalink) |
Freak Poster Join Date: Apr 2013 Location: Gujrat Age: 31
Member: 1912761 Status: Offline Sonork: 100.1650678 Thanks Meter: 105 | How to repair IMEI Samsung Tab P5220 with Z3X? Here are the logs. Selected model: P5200 Selected port: COM3 Z3X BOX Serial Port Selected port speed: 115200 Waiting ADB device... OK Reading phone info... Model: GT-P5220 Android version: 4.2.2 Product code: Not Active Phone version: P5220XXUANB2 PDA version: P5220XXUANB6 CSC version: P5220OJVANB1 IMEI: 004999010640000 Phone S/N: Unknown Checking Super user right... true Reading nv data... OK Checking magic... OK Running zTool, please wait... error Done with Samsung Tool v.18.2 Selected model: P5200 Selected port: COM3 Z3X BOX Serial Port Selected port speed: 115200 Waiting ADB device... OK Reading phone info... Model: GT-P5220 Android version: 4.2.2 Product code: Not Active Phone version: P5220XXUANB2 PDA version: P5220XXUANB6 CSC version: P5220OJVANB1 IMEI: 004999010640000 Phone S/N: Unknown Checking Super user right... true Reading nv data... OK Checking magic... OK Running zTool, please wait... error Done with Samsung Tool v.18.2 Do you have any solution Z3X team? Please tell me Thanks. |
10-24-2014, 07:52 | #2 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,282 | Quote:
03-22-2015, 21:16 | #3 (permalink) |
Freak Poster Join Date: Mar 2011
Member: 1538832 Status: Offline Sonork: bassgsm Thanks Meter: 10 | help me to repair imei p5220 Selected model: P5200 Selected port: COM5 Z3X BOX Serial Port Selected port speed: 115200 Searching Samsung modem... detected COM210 Reading phone info... Software version: P5220XXUAMJ8/NONE/P5220VFGAMK1 IMEI: Done with Samsung Tool v.19.0 Selected model: P5200 Selected port: COM5 Z3X BOX Serial Port Selected port speed: 115200 Waiting ADB device... OK Reading phone info... Model: GT-P5220 Android version: 4.2.2 Product code: Unknown Phone version: Unknown PDA version: P5220XXUAMJ8 CSC version: P5220VFGAMK1 IMEI: Unknown Phone S/N: Unknown Checking Super user right... true Reading nv data... OK Checking magic... SSNV not found Done with Samsung Tool v.19.0 |
03-22-2015, 21:18 | #4 (permalink) |
Member: 1538832 Status: Offline Sonork: bassgsm Thanks Meter: 10 | repair imei p5220 help me to repair imei p5220 Selected model: P5200 Selected port: COM5 Z3X BOX Serial Port Selected port speed: 115200 Searching Samsung modem... detected COM210 Reading phone info... Software version: P5220XXUAMJ8/NONE/P5220VFGAMK1 IMEI: Done with Samsung Tool v.19.0 Selected model: P5200 Selected port: COM5 Z3X BOX Serial Port Selected port speed: 115200 Waiting ADB device... OK Reading phone info... Model: GT-P5220 Android version: 4.2.2 Product code: Unknown Phone version: Unknown PDA version: P5220XXUAMJ8 CSC version: P5220VFGAMK1 IMEI: Unknown Phone S/N: Unknown Checking Super user right... true Reading nv data... OK Checking magic... SSNV not found Done with Samsung Tool v.19.0 |
03-23-2015, 09:50 | #5 (permalink) | |
Member: 1912761 Status: Offline Sonork: 100.1650678 Thanks Meter: 105 | Quote:
Flash P5220 with latest firmware, your imei will be 00490xxxxxxxxxxx. then try to write imei with octopus. Because at the moment Z3X does not support for IMEI repair for this model. Octopus can only repair old MCU. New type of MCU is also not supported by any box at the moment. Wait for new updates, BR | |
01-11-2017, 11:39 | #6 (permalink) |
Freak Poster Join Date: Feb 2008
Member: 714291 Status: Offline Thanks Meter: 39 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity and make backup before. 8. Press 'Disable Factory Mode' if needed. Operation: Repair Selected model: GT-P5220 Software version: 27.7 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... Ok Reading phone info... Model: GT-P5220 Android version: 4.4.2 Product code: Not Active Phone version: P5220XXUBNK1 PDA version: P5220XXUBOB1 CSC version: P5220SFRBOB1 CSC country code: France CSC sales code: SFR HW version: REV__ Phone SN: Modem board: XMM7160 RF cal date: Unknown IMEI: 004999010640000 Checking Super user right... true Reading NV data... Ok Checking magic... Ok Running zTool, please wait... error (7.4) Done with Samsung Tool PRO v.27.7 |
