07-07-2009, 10:06 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Kumasi-Ghana
Member: 390204 Status: Offline Sonork: 100.1592805 Thanks Meter: 138 | <<<<< How to repair KS20>>>>> [Solved] Please i need help it is very urgent... Thanks |
The Following User Says Thank You to karikari For This Useful Post: |
07-07-2009, 11:55 | #2 (permalink) |
Member: 390204 Status: Offline Sonork: 100.1592805 Thanks Meter: 138 | <<<<<<<<<<ks20 error>>>>>>>>>>. ks20 can not repair 7/7/2009 10:43:13 AM: Start repair! 7/7/2009 10:43:19 AM: Reading timeout, check cable 7/7/2009 10:43:19 AM: Error Code: CmdOpenNvmBlock 7/7/2009 10:43:19 AM: Reading timeout, check cable 7/7/2009 10:43:19 AM: Error write nvm! 7/7/2009 10:43:19 AM: Elapsed: 51 secs. 7/7/2009 10:43:19 AM: 7/7/2009 10:43:50 AM: Start repair! 7/7/2009 10:43:57 AM: Reading timeout, check cable 7/7/2009 10:43:57 AM: Error Code: CmdOpenNvmBlock 7/7/2009 10:43:57 AM: Reading timeout, check cable 7/7/2009 10:43:57 AM: Error write nvm! 7/7/2009 10:43:57 AM: Elapsed: 12 secs. 7/7/2009 10:43:57 AM: 7/7/2009 10:44:13 AM: Start repair! 7/7/2009 10:44:19 AM: Reading timeout, check cable 7/7/2009 10:44:19 AM: Error Code: CmdOpenNvmBlock 7/7/2009 10:44:19 AM: Reading timeout, check cable 7/7/2009 10:44:19 AM: Error write nvm! 7/7/2009 10:44:19 AM: Elapsed: 11 secs please help help...... |
07-07-2009, 14:34 | #3 (permalink) | |
Product Supporter Join Date: Mar 2005 Location: China
Member: 129885 Status: Offline Sonork: 100:1603514 Thanks Meter: 6,202 | Quote:
1. Select prope mode from phone menu , u need to enter some codes 2. Make shure that you correctly soldered TX and RX lines to testpoints | |
07-08-2009, 15:22 | #5 (permalink) |
Member: 390204 Status: Offline Sonork: 100.1592805 Thanks Meter: 138 | ks20 repair is ok now........ here is logs.. 7/8/2009 2:09:24 PM: Start repair! 7/8/2009 2:09:24 PM: Write NV... 7/8/2009 2:10:21 PM: Repair BT address done. 7/8/2009 2:10:21 PM: Repair IMEI done. 7/8/2009 2:10:21 PM: Repair done. 7/8/2009 2:10:21 PM: Elapsed: 63 secs. 7/8/2009 2:10:21 PM: Thanks to Z3x team.......... |
The Following 3 Users Say Thank You to karikari For This Useful Post: |
08-29-2009, 08:30 | #6 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 72951 Status: Offline Thanks Meter: 63 | One question, I saw the photo to solder to RX, TX, GND to phone but the RJ45 pinout I don't have? I never received any LG cables with my box, only Samsung and I purchased both Samsung and LG modules but I think looking at Z3x website they don;t offer LG cables, strange. Can someone supply please. Last edited by cracker_jack; 08-29-2009 at 08:37. |
08-29-2009, 13:37 | #7 (permalink) |
No Life Poster Join Date: Jul 2006 Location: Bangladesh Age: 42
Member: 319447 Status: Offline Thanks Meter: 4,949 | cracker_jack You can buy LG Cable set for Z3X Box separately. Its available |
The Following User Says Thank You to .:SUBRATA:. For This Useful Post: |
09-04-2009, 05:29 | #9 (permalink) |
Member: 72951 Status: Offline Thanks Meter: 63 | I really need some help here, please. I purchased the LG cable set for Z3X box for repairing KS20 IMEI but still there is no cable that can repair it. The KU311 USB cable alone will not work. I changed to English ROM and now no network and IMEI is all zero's. I can see the photo to solder RX, TX and GDN to the back of the KS20 but what cable is used for this? Is it RJ45 or USB. If RJ45 then what is the pinout? There is no pinout posted for the RJ45 anywhere and I can't see it being any cable from any phone? Please advise I need to repair this for my customer as soon as possible. Thank you in advanced. |
09-04-2009, 23:03 | #10 (permalink) |
Junior Member Join Date: Jul 2009 Location: www.mobile-flasher.com
Member: 1075136 Status: Offline Thanks Meter: 8 | I hope this can help you... If I'm not mistaken... for Uart = You can use Nokia DKU5 cable by modified... or you can use RJ45 with Z3x pin like shown below.... Z3x pin similar with Unibox and Infinity pinout. Best Regards |
The Following User Says Thank You to Yoan Rivky For This Useful Post: |
09-04-2009, 23:10 | #11 (permalink) |
Member: 1075136 Status: Offline Thanks Meter: 8 | Sorry,... pictures size i uploaded above is too large... maybe mod can resize it... @cracker_jack : if you want to fast replay from Z3x team, you can post your problem by make a new thread, and do not use the solved thread (as like closed topic thread), so Z3x team will check your problem as soon as possible... (tested by me) |
09-05-2009, 02:52 | #12 (permalink) |
Member: 72951 Status: Offline Thanks Meter: 63 | Thanks Yoan Rivky for your help but unfortunately this RJ45 pinout didn't work for me. I checked and doubled checked everything and Z3X Box keeps saying check cable. Voltage is correct, soldering is correct, just don't get it. Any other suggestions, maybe I am still doing something wrong.....thanks for your pics too. |
The Following User Says Thank You to cracker_jack For This Useful Post: |
how to repair ku990i yellow screen (refreshing) | 4given4gotten | FuriousGold | 1 | 03-29-2010 17:43 |
how to repair SUPERDONGLE[SOLVED] | sr8787 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 02-20-2010 13:08 |
How to repair imei ks360 with z3x [Solving] | luyanda | Z3X-Team Products | 1 | 10-13-2009 18:56 |
How to repair imei in x650 [Solved] | nilan | Z3X-Team Products | 3 | 09-17-2009 11:54 |
