09-19-2012, 18:46 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Birmingham U.K
Member: 251421 Status: Offline Sonork: 100.1609329 Thanks Meter: 439 | SAMSUNG S5830i 2.3.6 UNLOCK SOLVED WITH MANUAL ROOT. PLEASE CHECK INSIDE FOR METHOD DOWNLOAD FILE UPDATE.ZIP https://rapidshare.com/#!download|19...e.zip|1165|0|0 1)Put file in a memory card 2)insert memory card in phone 3)hold volume up + home + power for about 15-20 sec phone will go in recovery menu 4)select apply update from sd card. 5)select update.zip it will say installing update than install complete. 6)now reboot you phone. 7)switch on usb debuging from setting >Application > Development connect with Pc/Laptop Install Drivers and Unlock using Z3x Box. [PLEASE NOTE] During unlock might on phone screen it will ask you to click on allow. Count supported models - 319 Android Version: 2.3.6 Model: GT-S5830i Product Code: Unknown Phone Version: S5830iXXLB1 PDA Version: S5830iXXLB2 CSC Version: S5830iO2ULB1 IMEI: 352753XXXXXXXX7 Checking ROOT... TRUE Reading Data From Phone... OK Unlocking... OK Rebooting Phone... OK Done with Samsung Tool ver 12.7 I understand its not any Major thing to Explain but there are some new user may it will help them. Facebook.com/Malikzahidawan Facebook.com/MobileGadgetsUK |
The Following 10 Users Say Thank You to malikzahidawan For This Useful Post: |
10-01-2012, 14:51 | #2 (permalink) |
Freak Poster Join Date: May 2007 Location: Kumasi;Ghana\west africa Age: 38
Member: 510345 Status: Offline Thanks Meter: 40 | Count supported models - 319 Searching Samsung USB Modem... Detected (COM74) Model: GT-S5830i SW: BCM21553_Modem_SI1220.2_V2.4 IMEI: 353924050389588 Done with Samsung Tool ver 12.7 Phone Not Found Done with Samsung Tool ver 12.7 Searching Samsung USB Modem... Detected (COM74) Model: GT-S5830i SW: BCM21553_Modem_SI1220.2_V2.4 IMEI: 353924050389588 Done with Samsung Tool ver 12.7 Android Version: 2.3.6 Model: GT-S5830i Product Code: Unknown Phone Version: S5830iXXLD2 PDA Version: S5830iXXLE3 CSC Version: S5830iO2ULE1 IMEI: Unknown Checking ROOT... TRUE Reading Data From Phone... OK Unlocking... OK Rebooting Phone... OK Done with Samsung Tool ver 12.7 Android Version: 2.3.6 Model: GT-S5830i Product Code: Unknown Phone Version: S5830iXXLD2 PDA Version: S5830iXXLE3 CSC Version: Unknown IMEI: Unknown Checking ROOT... TRUE Reading Data From Phone... OK Unlocking... OK Rebooting Phone... OK Done with Samsung Tool ver 12.7 Phone Not Found Done with Samsung Tool ver 12.7 Phone Not Found Done with Samsung Tool ver 12.7 Phone Not Found Done with Samsung Tool ver 12.7 Searching Samsung USB Modem... Detected (COM74) Model: GT-S5830i SW: BCM21553_Modem_SI1220.2_V2.4 IMEI: 353103055181684 Done with Samsung Tool ver 12.7 Phone Not Found Done with Samsung Tool ver 12.7 Android Version: 2.3.6 Model: GT-S5830i Product Code: Unknown Phone Version: S5830iXXLD2 PDA Version: S5830iXXLE3 CSC Version: S5830iO2ULE1 IMEI: Unknown Checking ROOT... TRUE Reading Data From Phone... OK Unlocking... OK Rebooting Phone... OK Done with Samsung Tool ver 12.7 Android Version: 2.3.6 Model: GT-S5830i Product Code: Unknown Phone Version: S5830iXXLD2 PDA Version: S5830iXXLE3 CSC Version: S5830iO2ULE1 IMEI: Unknown Checking ROOT... TRUE Reading Data From Phone... OK Unlocking... OK Rebooting Phone... OK Done with Samsung Tool ver 12.7 |
The Following 2 Users Say Thank You to ASIEDU ANNOR For This Useful Post: |
10-09-2012, 16:09 | #3 (permalink) |
Insane Poster Join Date: May 2012 Location: lorca Age: 42
Member: 1755990 Status: Offline Thanks Meter: 1 | Count supported models - 319 Android Version: 2.3.6 Model: GT-S5830i Product Code: Unknown Phone Version: S5830iXXLB1 PDA Version: S5830iBGLB3 CSC Version: S5830iXECLB1 IMEI: 352289050545022 Checking ROOT... FALSE Rooting Phones, Please Wait... OK Checking ROOT... FALSE Done with Samsung Tool ver 12.7 |
10-09-2012, 17:23 | #8 (permalink) |
No Life Poster Join Date: Sep 2010 Location: In trouble Age: 49
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | Ok if this doesn't work for you, try to flash a lower firmware, under v2.3.5. So this way z3x will root your phone on it's own, no more problem. |
10-16-2012, 00:27 | #10 (permalink) |
Member: 251421 Status: Offline Sonork: 100.1609329 Thanks Meter: 439 | [QUOTE=youssefmcs;8828939]any help please thanks in advence[/QUOTE Make sure to click on allow when it ask you on phone |
The Following User Says Thank You to malikzahidawan For This Useful Post: |
