Old 04-03-2012, 22:28   #1 (permalink)
inside-d-saul's Avatar
Member: 581626
Thanks Meter: 184
How to Root Samsung phones for unlock with Z3X
This work with the following devices:
GT-S5570, GT-S5570B, GT-S5570I, GT-S5570L, GT-S5660, GT-S5660M, GT-S5660L, GT-S5670, GT-S5670B, GT-S5670L, GT-S5830, GT-S5830B, GT-S5830C ,GT-S5830D, GT-S5830i, GT-S5830L, GT-S5830T, GT-B7510, GT-S5360, GT-S5360L, GT-S5360T, GT-S5363, GT-S5690.
How to Root: ( from another site)
- First enable Unknown sources on your phone (Settings -> Applications -> Unknown sources)
- Download the Universal_GB_ROOT_v9.zip file and put in your SD card.
- After transferring your file on your phone disable the USB by pressing "Disconnect storage from PC" after that remove the USB cable and turn off your phone "Power off".
- Make shure you start the phone like this : Long press and hold the (Power Button) + (Home Button) ( if not work you must use Power and Volume+ )
- After couple of seconds you will see your phone booting in recovery mode
- Move in the menu with the Volume - Volume + to scroll up and down and choose "apply update from sdcard" and go directly to the folder that you already created Applications insert in the folder with the Home button and choose the Universal_GB_ROOT_v9.zip and press once again the Home button to apply it.
- You will see a message "Install form sdcard complete".
- Then press on the "reboot system now" and you are done.
Download link for Universal Gingerbread Root (by StoneBoyTony) :
after that make unlock with z3x again.
Thats all
The Following 25 Users Say Thank You to inside-d-saul For This Useful Post:
Old 04-04-2012, 01:58   #2 (permalink)
Vijendra Saini's Avatar
Member: 398557
Sonork: 100.1578489
Thanks Meter: 1,516
Thanks for the sharing your knowledge here.
Vijendra Saini.
Old 04-04-2012, 11:39   #3 (permalink)
Member: 1036967
Thanks Meter: 7
thank you so much good work man
Old 04-12-2012, 11:06   #4 (permalink)
kjava's Avatar
Member: 846616
Sonork: 100.1675590
Thanks Meter: 581
it work for S5830i v2.3.6?
Old 04-13-2012, 09:16   #5 (permalink)
Member: 165059
Thanks Meter: 23
ITs work with 5570i
Count supported models - 302
Searching Samsung USB Modem... Detected (COM33)
Model: GT-S5570i
SW: BCM21553_Modem_SI1220.2_V2.4
IMEI:
Done with Samsung Tool ver 12.2
Starting ADB Server... OK
Checking ROOT... TRUE
Reading Phone Info... OK
Android Version: 2.3.6
Model: GT-S5570I
Phone Version: S5570IXXLB1
PDA Version: S5570IBGLB1
CSC Version: S5570IXECLA2
IMEI:
Reading Data From Phone... OK
Unlocking... OK
Thanks
The Following User Says Thank You to AquilesLynott For This Useful Post:
Old 04-19-2012, 12:01   #6 (permalink)
Member: 88552
Thanks Meter: 13
S5363 unlock ok
IMEI: 358841042254545
Done with Samsung Tool ver 12.3
Model: GT-S5363
Product Code: Unknown
Phone Version: Unknown
PDA Version: S5363XXKK3
CSC Version: Unknown
IMEI: Unknown
Please Wait, Calculating Codes... OK (time - 00:01:00)
Freeze code: 10105050
NET lock: #7465625*638*60605030#
Sub lock: #7465625*782*60605030#
SP lock: #7465625*77*00000000#
CP lock: #7465625*27*00000000#
Multi lock: #7465625*685*00000000#
For check lock status: *#7465625#
thank a lot
Old 04-19-2012, 12:09   #7 (permalink)
anwar.welltech's Avatar
Member: 952533
Sonork: 1001607366
Thanks Meter: 124
good work keep it up
Old 04-19-2012, 14:58   #8 (permalink)
Member: 1269598
good work
s5363 v2.3.6 unlock donne
Old 04-26-2012, 10:13   #9 (permalink)
Member: 232607
Sonork: 100.1585040
Thanks Meter: 260
Searching Samsung USB Modem... Detected (COM149)
Model: GT-S5360
IMEI: 351863056207562
Model: GT-S5360
Phone Version: S5360XXKL3
PDA Version: S5360XXKL3
CSC Version: S5360ORRKL1
Unlocking... OK
successfully unlock done
Old 04-30-2012, 20:01   #10 (permalink)
Member: 1711459
please help the drivers
Old 05-01-2012, 22:25   #11 (permalink)
Member: 581626
Thanks Meter: 184
as you wish this-is-what-you-want
Old 05-01-2012, 23:09   #12 (permalink)
dragosgsm's Avatar
Member: 148032
Thanks Meter: 415
Wink
installing Samsung Kies will "help the drivers" on evrey Samsung phone...
Old 05-02-2012, 12:31   #13 (permalink)
umarnlw's Avatar
Member: 207708
Sonork: 100.1602241
Thanks Meter: 1,005
Any one upload video please
Old 05-02-2012, 19:05   #14 (permalink)
Member: 581626
Thanks Meter: 184
which device you have? what is the problem?
Old 05-02-2012, 20:58   #15 (permalink)
dragosgsm's Avatar
Member: 148032
Thanks Meter: 415
doesen't work on s5690!!!!!!!
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
Page generated in 0.22234 seconds with 10 queries
