Old 01-08-2014, 18:48   #1 (permalink)
Registered User
Member: 1214756
Thanks Meter: 53
I9100 IMEI 004999010640000/01 solucation ?
any one have solucation pls shareee
Old 01-08-2014, 18:54   #2 (permalink)
Registered User
Member: 1214756
Thanks Meter: 53
running zTool, please wait ....
on this stage i got the error
any one have idea...........
Old 01-08-2014, 19:02   #3 (permalink)
hamzamobile55's Avatar
Member: 1878900
Thanks Meter: 121
first must need phone is rooted
and
which cable you used usb or uart?
Old 01-08-2014, 20:01   #4 (permalink)
Member: 1216263
Thanks Meter: 130
Downgrade to Samsung Tool 16.2 and it will work.
Old 01-08-2014, 21:10   #5 (permalink)
lahdache's Avatar
Member: 820444
Sonork: 100.1680641
Thanks Meter: 466
steps :
1- root phone
2- use c3303 cable
3- repair ime : click repair entre your imie.
reg
Old 01-10-2014, 08:28   #6 (permalink)
Registered User
Member: 1214756
Thanks Meter: 53
DOWNGRADE THE samsung tool but same error............
any one have tested solucation.......
Old 01-10-2014, 08:39   #7 (permalink)
Member: 1759873
Thanks Meter: 3
repair S/N in first and after you repair imei
Old 01-10-2014, 09:54   #8 (permalink)
Registered User
Member: 1214756
Thanks Meter: 53
and
phone rooted and using usb cable
and trying with uart but not connecting........
Old 01-10-2014, 10:01   #9 (permalink)
cavalierks's Avatar
Member: 1523083
Sonork: 100.1609029
Thanks Meter: 141
Try with fw 2.3.6 need root repair efs after imei
Envoyé de mon iPhone à l'aide de Tapatalk
Old 01-10-2014, 10:04   #10 (permalink)
ms phone's Avatar
Member: 1119242
Sonork: 100.1638541
Thanks Meter: 121
use samsung tool lower version last day im succses use samsung version 15.2 or 12.1
Old 01-11-2014, 10:16   #11 (permalink)
Registered User
Member: 1214756
Thanks Meter: 53
samsung tool downgraded and mobile ver also downgraded
phone also rooted
but same problem
how to slove.................
Old 01-11-2014, 19:56   #12 (permalink)
Member: 1878900
Thanks Meter: 121
phone also rooted
but same problem
try uart cable also select uart setting
then post screenshot
Old 01-12-2014, 00:51   #13 (permalink)
Yakub Alli's Avatar
Member: 1022144
Sonork: Love in Bangladesh
Thanks Meter: 139
1st root , 2nd mark Debugging , 3rt try write imei with usb cable ........
Old 01-14-2014, 15:45   #14 (permalink)
Registered User
Member: 1214756
Thanks Meter: 53
uart se kiyato connect nahi horaha................
process :You need to swith UART and USB settings:
enter UART mode with *#9090# and select "Log via UART"
then
enter *#7284# and select "UART MODEM" and select "USB PDA
is procesegarme kiya............
Old 01-15-2014, 02:59   #15 (permalink)
richiricherd's Avatar
Member: 594580
Thanks Meter: 157
Hey mate i was facing same problem than you, but i could find solution, that is samsungtool version 16.8 is not good for i9100, i just installed version 15.0 and that is it.. Done..
Page generated in 0.21385 seconds with 9 queries
