how to unlock e2222 duos using z3x Problem : Provider lock Phone (globe telecom) gadgets: Z3X box Samsung Activated reminders: update your z3x box to latest version for best result. Tutorial : first : -open z3x shell . -select samsung module. -select e series. -find e2222 model. second : -find cable optional to used micro uart cable by z3x box(buy it you will need it for future phone) -select com port (if you dont know which port to used ,right click computer,select hardware tab, select device manager, lock for port tree, see which port does your z3x box used) -un check everything in settings if using micro uart cable go to setting - select tat mode and uncheck usb else - select flash mode and usb 3rd : -prepare phone -remove battery tick direct_unlock or read_code button -hold KEY( qwas ) -inset usb -insert battery phone will set in tat mode wait for a few seconds to a minute (don't disconnect if it take prolong) your done thanks to z3x team for update .. :):):):):) |
Selected model: C3322 Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone SW: E2220CEKI1 Phone CSC: E2220OCEKH3 Phone BT ADDR: 9451-03-BE37EE Phone IMEI: 35821404087744 Deactivated MSL - FAIL Elapsed time: 33 second, sw ver: 3.5.0033 --------------------------------------------------------- |
Selected model: E2222 Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone SW: E2220CEKI1 Phone CSC: E2220OCEKH3 Phone BT ADDR: 9451-03-BE37EE Phone IMEI: 35821404087744 Deactivated MSL - FAIL Elapsed time: 23 second, sw ver: 3.5.0033 |
yessssssssssssssssssssssssssssssssssss Selected model: E2220 Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 35821404087744 Phone SW: E2220CEKI1 Phone CSC: E2220OCEKH3 Phone BT ADDR: 9451-03-BE37EE Phone SN: RUDB965144 [FREZEE]:47968410 [NET LOCK]:00013300 [Subset LOCK]:00000000 [SP LOCK]:56735250 [CP LOCK]:00000000 [Sim LOCK]:00000000 [Activa LOCK]:00000000 [Phone LOCK]:00000000 Read info - ok Elapsed time: 10 second, sw ver: 3.5.003 |
Selected model: E2222 Selected com port: COM3 Selected speed port: 921600 Press "volume down" + "lock" and connect USB cable to phone Connect to control pipe... OK Processor ID -> 0A34 Sending loader... OK Connect to control pipe... OK Connect to write pipe... OK Connect to read pipe... OK Damping... OK Erasing... OK Sending... OK Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 61 second, sw ver: 3.5.0035 ------------------------------------------------------------------------------- thanks good info |
Selected model: E2222 Selected com port: COM9 Selected speed port: 921600 Press "volume down" + "lock" and connect USB cable to phone Connect to control pipe... OK Processor ID -> 0A34 Sending loader... OK Connect to control pipe... OK Connect to write pipe... OK Connect to read pipe... OK stuck this place above 15 minutes,,,wat will i do? |
what diffarent micro uart cable ca 101d usb cable |
E2222 password Selected model: E2222 Selected com port: COM42 Selected speed port: 921600 Press "volume down" + "lock" and connect USB cable to phone Connect to control pipe... OK Processor ID -> 0A34 Sending loader... OK Connect to control pipe... OK Connect to write pipe... OK Connect to read pipe... OK Damping... OK Phone master IMEI -> 35683304195462 Phone slave IMEI -> 35713904195462 Phone SW -> E2222JVKE1 Langpack-> Algeria, Egypt, Iran, Iraq, Kuwait, Morocco, Nigeria, Oman, Pakistan, Saudi Arabia, South Africa, Syria, Tunisia, Turkey Phone HW -> MP 0.400 Phone BT ADDR -> 8C77-12-8F9D46 Read Info - ok Elapsed time: 100 second, sw ver: 3.5.0040 am not getting password please direct me the right wat |
