Old 05-07-2013, 13:49   #1 (permalink)
Member: 588045
Thanks Meter: 19
how to unlock galaxy s4 z3x
plzzzzz guide me
Old 05-07-2013, 13:58   #2 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 173,484
plzzzzz guide me
exist 10+ different galaxy s4 models.
If you want help - read stiked thread what information need provide if you want help from support.
The Following 2 Users Say Thank You to blang For This Useful Post:
Old 05-09-2013, 21:18   #3 (permalink)
vistaunlock's Avatar
Member: 497776
Thanks Meter: 37
Selected model: I9500
Selected port:
Selected port speed: 115200
Searching Samsung modem... not found
Done with Samsung Tool v.14.4
cannot detect com port whats problem i have latest driver and samsung kies , phone rooted ....
Old 05-09-2013, 23:06   #4 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Selected port:
you need switch on debug mode,
The Following User Says Thank You to blang For This Useful Post:
Old 05-10-2013, 00:47   #5 (permalink)
tatoapf's Avatar
Member: 197641
Thanks Meter: 58
Same here
Selected port: COM16 Z3X BOX Serial Port
Searching Samsung modem... detected COM166
Reading phone info...
Software version: I9500UBUAMDE/I9500UBUAMDE/I9500UWAAMDE
IMEI: 35579905352xxx
Phone not found
Old 05-10-2013, 02:23   #6 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Originally Posted by tatoapf View Post
Same here
Phone not found
Yes. same here. Switch phone to diagnostic mode, install drivers android, root phone , only then you can unlock phone
Old 05-10-2013, 07:17   #7 (permalink)
tatoapf's Avatar
Member: 197641
Thanks Meter: 58
Mr Blang, with all the respect you deserve, I not a noobie here, if I posted that is because the phone was already rooted, diagnostic mode enabled and all drivers installed.
Regards,
TaTo
Old 05-10-2013, 16:35   #8 (permalink)
kaderlamine's Avatar
Member: 1186610
Thanks Meter: 330
Samsung Tool v14.4 (without root)
How to:
- Cable UART C3300K
- Select com port box in ST software
- Press *#7284# and select "Modem"
(Only show one option interface "UART")
*default setting: "PDA"
- Press *#9090# and select "4 - DM over UART"
*default setting: "DM/DUN over HS-USB"
- Press "Unlock"
Selected model: I9505
Selected port: COM13 Z3X BOX Serial Port
Build: M9615A-CEFWTAZM-4.0.17062
Reading security... OK
Calculating... OK
Writing security... OK
Reseting...
Unlock done
The Following 3 Users Say Thank You to kaderlamine For This Useful Post:
Old 05-10-2013, 17:33   #9 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Regards,
TaTo
Sorry, but but lets not talk offtopic things,
every day samsung released new firmware and things changes. So not importat who is noobie or not.
I have i9500 2 weeks in my hands and i sure software working well.
Just check this:
How to fix ?ADB Device is listed as offline? on android 4.2.2? | WugFresh
If you press only one time [accept],android device will go offline after first acces to phone. For unlocking need few request. So just simple way, reconect phone and just choise [never ask].
I sure problem will be solved.
Even if problem will still exist on your side, contact to me via sonork 100.111111 and i will check where is problem.
Old 05-11-2013, 14:16   #10 (permalink)
Member: 497776
Thanks Meter: 37
itry and conected now but unlock not working stuck here :
Selected port:
Searching Samsung modem... detected COM21
Software version: I9500XXUAMDE/I9500XXUAMDE/I9500OJVAMDC
IMEI: 355799050881646
Selected port:
Old 05-11-2013, 19:03   #11 (permalink)
y3kt's Avatar
Member: 238127
Sonork: 100.1574867
Thanks Meter: 3,516
Hi, I am having the exact same problem, phone rooted drivers installed and I get stuck here as well:
Selected port:
Searching Samsung modem... detected COM85
IMEI: 355799053526131
Selected port:
If I removed the cable then I get this added to the log.
Model: Unknown
Android version: Unknown
Product code: Unknown
Phone version: Unknown
PDA version: Unknown
CSC version: Unknown
IMEI: Unknown
Checking Super user right... false
Rooting phone, please wait... error
Not supported android version Unknown
Can you tell us which driver are you using?
ADB is not a problem anymore since I have updated it everywhere in the PC to latest version.
Old 05-13-2013, 16:15   #12 (permalink)
y3kt's Avatar
Member: 238127
Sonork: 100.1574867
Thanks Meter: 3,516
Any update on this, supporter?
Old 05-13-2013, 16:59   #13 (permalink)
Crazy Poster
Member: 434758
Sonork: 100.1673992
Thanks Meter: 2
samsung i9505 unlock done
Selected port: COM3 Z3X BOX Serial Port
Calculating... OK
Reseting...
Unlock done
Old 05-13-2013, 17:29   #14 (permalink)
Member: 497776
Thanks Meter: 37
Selected port: COM5 Z3X BOX Serial Port
Reading phone info... no answer from phone
Old 05-13-2013, 17:31   #15 (permalink)
Member: 497776
Thanks Meter: 37
Mr inovator i have i9500 and i try hard from friday unlock and not done with me
plz if u can help me im very thnaxfull
phone rooted
Page generated in 0.41545 seconds with 7 queries
