Old 05-13-2013, 21:41   #16 (permalink)
zeroualot_7's Avatar
Member: 112112
Sonork: 100.1621373
Thanks Meter: 138
Pls how to unlock s4 i9500 with z3x
Old 05-13-2013, 22:29   #17 (permalink)
y3kt's Avatar
Member: 238127
Sonork: 100.1574867
Thanks Meter: 3,510
Originally Posted by inovator 2006 View Post
Selected model: I9505
Selected port: COM3 Z3X BOX Serial Port
Selected port speed: 115200
Reading phone info...
Build: M9615A-CEFWTAZM-4.0.17062
Reading security... OK
Calculating... OK
Writing security... OK
Reseting...
Unlock done
Done with Samsung Tool v.14.4
There is a big difference between I9500 and I9505, we are dealing here with I9500 so please, anyone whilling to post something make sure it is an I9500 before.
Old 05-14-2013, 09:45   #18 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 171,529
root phone,
switch on debug mode,
press unlock
Old 05-14-2013, 13:49   #19 (permalink)
Member: 112112
Sonork: 100.1621373
Thanks Meter: 138
not work for me
Originally Posted by blang View Post
root phone,
press unlock
Selected model: I9500
Phone not found
Model: Unknown
Android version: Unknown
Product code: Unknown
Phone version: Unknown
PDA version: Unknown
CSC version: Unknown
IMEI: Unknown
Checking Super user right... false
Rooting phone, please wait... error
Not supported android version Unknown
Old 05-14-2013, 15:09   #20 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Phone not found
Model: Unknown
IMEI: Unknown
Contact with me now in sonork 100.111111 and your phone will be unlocked in few minutes
Old 06-30-2013, 20:57   #21 (permalink)
Member: 1867931
Sonork: 100.1625521
Thanks Meter: 36
step by step
Selected port: COM9 Z3X BOX Serial Port
Model: GT-I9500
Android version: 4.2.2
Product code: GT-I9500ZWLJDI
Phone version: I9500XXUAMDK
PDA version: I9500XXUAMDK
CSC version: I9500SERAMDK
IMEI: Unknown
Checking Super user right... true
Reading data from phone... OK
Unlocking... OK
Rebooting phone... OK
Unlock done
Instructions:
1. Download this flash file from link below and flash via ODIN
Hotfile.com: One click file hosting: I9500XXUAMDK_I9500SERAMDK_SER.zip
2. Root with this boot file ( will unload in a few mins). Flash in ODIN as PDA
3.Turn on Debugging Mode. Plug in to PC. Open Supersu and update binary
4.Set Z3X to i9500 and Click unlock.
Works Perfect!!! Good luck
Thank you again Blang!!
follow me here plz https://www.facebook.com/pages/Cooll...99300016867910
Old 07-01-2013, 09:05   #22 (permalink)
Gjakova's Avatar
Member: 189304
Sonork: 100.1614605
Thanks Meter: 40
Calculating... OK
Reseting...
Unlock done
Done with Samsung Tool v.14.9
Old 07-01-2013, 19:06   #23 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 342
Reading security... error access denied
What is the solution ?
Phone is rooted , debugging on .
Old 07-02-2013, 13:10   #24 (permalink)
Member: 1954027
Get Sim Network Unlock PIN from any trusted phone unlocking website.
Old 07-02-2013, 14:31   #25 (permalink)
Member: 1945073
The following are tips to unlock the T-Mobile Samsung Galaxy S IV with Z3X box. I have tried the steps below and it worked for me. It's not simple to get it right because of lack of information available somewhere else.
Connect Z3X box to PC via USB.
Enable USB debug on the phone.
Dial *#7284# on the phone, choose Quadcomm USB settings -> DM + Modem + ADB
Connect T-Mobile Samsung Galaxy S IV T659 to PC via a different USB port.
Select model T659 in Samsung tool 13.1.
Select the USB port and then click unlock. The phone will reboot itself after unlock is done.
Congratulations, now you have just unlocked your T-Mobile Samsung Galaxy S4!
To verify whether it's unlocked or not, just pop in a sim card from another carrier (for example, AT&T), and reboot the phone. If the phone is not unlocked, it will prompt you for unlock code upon startup.
Old 07-03-2013, 10:20   #26 (permalink)
Member: 127430
Thanks Meter: 11
DOWNGRADE NEEDED FOR SURE
You need to put phone in this mode:
*#7284#
UART:
*modem
USB:
*pda
Qualcoom setiings:
*DM MODEM ADB
*#9090#
*4dm over uart
*#0808#
ap
*dm+modem+adb
1. Goto SETTINGS
2. Click ABOUT DEVICE
3. Trap 7 Times on the BUILD NUMBER.
Once done you should get a message stating "You Are Now A Developer"
once you have seen the message you can then go back to settings and you should have the option "Developer
Options", now you can enable USB Debugging.
Selected port: COM48 SAMSUNG Mobile USB Serial Port
Calculating... OK
Reseting...
Unlock done
CHECK ALL TIME *#9090# IF dm over uart
Old 11-07-2013, 12:33   #27 (permalink)
Member: 1315616
Thanks Meter: 4
samsung s4 z3x unlock ok but network unlock pin not ok help me
Old 11-07-2013, 14:37   #28 (permalink)
Member: 1752465
Thanks Meter: 32
i have same problem........how to solve ?????????????????????
Old 11-12-2013, 13:45   #29 (permalink)
Member: 1872574
Sonork: 100.1625986
Thanks Meter: 26
~~~~~~~~~~~~~~~unlock done I9505~~~~~~~~~~~~~~~~~
How to:
- Cable UART C3300K...............
- Select com port box in ST software
- Press *#7284# and select "Modem"
(Only show one option interface "UART")
*default setting: "PDA"
- Press *#9090# and select "4 - DM over UART"
*default setting: "DM/DUN over HS-USB"
- Press "Unlock"......................
Selected port: COM13 Z3X BOX Serial Port
Calculating... OK
Reseting...
Unlock done~~~~~~~~~~~~~~
The Following User Says Thank You to md_koyes For This Useful Post:
Old 11-12-2013, 14:15   #30 (permalink)
ben khalifa's Avatar
Member: 1122865
Thanks Meter: 40
wath is probleme........
Model: GT-I9500
IMEI: 357138058418168
Phone S/N: Unknown
Reading data from phone... error
Done with Samsung Tool v.16.1
i cant unlck it pleas help me
Page generated in 0.35854 seconds with 7 queries
