07-12-2012, 13:44 | #5 (permalink) |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | i747 done with T999 model i747 done with T999 model: Checking Phone On COM4... OK Reading Phone Info... OK Build: M8960A-AAAANAZM-1.0.442802 IMEI: 353091050056094 Done with Samsung Tool ver 12.6 Reading Phone Info... OK Build: M8960A-AAAANAZM-1.0.442802 IMEI: 353091050056094 Reading Security... OK Calculating... OK Unlocking ... OK Done with Samsung Tool ver 12.6 BillA |
07-12-2012, 19:07 | #6 (permalink) | |
Insane Poster Join Date: Oct 2008 Location: Việt Nam
Member: 885342 Status: Offline Sonork: congthanh211 Thanks Meter: 7 | Dear BillA Quote:
after typing * # 9090 # usb choose which ones that? thank you very much, I have installed the usb port but not search phone. again thank a lot!. I look forwards to hearing from you. Regards, | |
07-14-2012, 08:58 | #7 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Sydney Age: 37
Member: 1205146 Status: Offline Thanks Meter: 879 | I got same phone as well. Its rooted, \With UART cable it says " Code: Reading Phone Info... OK IMEI: 000000000000000 Reading Security... Error Done with Samsung Tool ver 12.6 Code: Searching Samsung USB Modem... Detected (COM212) Model: SAMSUNG-SGH-I747 IMEI: I747UCLEM Done with Samsung Tool ver 12.6 LITTLE MASTER |
07-14-2012, 12:00 | #8 (permalink) |
Freak Poster Join Date: May 2004 Location: UK
Member: 65097 Status: Offline Sonork: 100.111703 Thanks Meter: 7 | i747m confirm unlock with z3x 12.6 this is what i did: Code: 1. Connect phoen to PC powered via USB and enter MTP mode (Media Transfer) 2. Copy 'SuperUser.zip' to the root of Internal Storage 3. Power off phone and go into Download Mode (Volume Down + Home + Power -- Then press Volume Up to continue) 4. Open Odin 1.85+ 5. Add 'RecoveryGalaxyS3USCanada.tar' into PDA and flash 6. As soon as flash finishes - remove battery 7. Reinsert battery and enter recovery mode (Volume Up + Home + Power -- Only hold power for around 3 seconds) 8. Once in recovery, select 'install zip from sdcard' then 'choose zip from internal sdcard' 9. Next select 'SuperUser.zip' and confirm 10. Once you get 'Install from sdcard complete' go back and reboot and root should be complete. 11. once restarted - do a full reset (*2767*3855#) 12. *#7284# - select modem 13. *#9090# - select USB and reboot phone 14. Make sure device is in USB Debugging mode and connect with C3300k cable directly to z3x. 15. open Samsung Tool 12.6 and select T989 as model and select COM for box and press unlock. and this is my unlock log: Code: -------------------------- 14.7.2012_10-31-9 -------------------------- Count supported models - 315 Reading Phone Info... OK Build: M8960A-AAAANAZM-1.0.442802 IMEI: ***********2467 Reading Security... OK Calculating... OK Unlocking ... OK Done with Samsung Tool ver 12.6 |
The Following User Says Thank You to _mo_ For This Useful Post: |
07-14-2012, 12:24 | #9 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @_mo_ you can skip rooting for phones unlock over qc mode. rooting for unlocking is useless all this phones. basic info for all. I727,I727M,T989,T989D,T999,I747,I747M,T769 many other etc unlock in qualcomm mode. if modem is set on uart use uart cable for unlocking & repairing. if modem is set to usb use usb cable for unlocking & repairing. use this two codes to set need port setting. *#7284# *#9090# some phone like I747M have switching blocked(can't select),so people can use (*2767*3855#) to full reset phone then you can set it. Regards, Chevli Last edited by stanner_austin; 07-19-2012 at 16:21. Reason: info updated |
The Following User Says Thank You to stanner_austin For This Useful Post: |
07-14-2012, 13:02 | #10 (permalink) |
Member: 65097 Status: Offline Sonork: 100.111703 Thanks Meter: 7 | thank you for the heads up - i did try without rooting but kept failing. i rooted and it went straight through. i will try again with another one withour rooting thank you |
07-14-2012, 13:26 | #11 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: rainak bazar jalandhar
Member: 1002949 Status: Offline Sonork: 100.1582346 Thanks Meter: 273 | Quote:
07-14-2012, 14:09 | #12 (permalink) | |
Junior Member Join Date: Jun 2012
Member: 1773961 Status: Offline Thanks Meter: 0 | Quote:
I feel what austin has said is correct, rooting is not necessary. Since the moment you perform a factory reset, using the above command root is lost. You were still able to unlock your phone, this implies that the root is not required. I welcome to be corrected. | |
07-15-2012, 01:38 | #14 (permalink) |
Member: 1205146 Status: Offline Thanks Meter: 879 | unlock done UNLOCK DONE. ROOTING NOT NEEDED FOT THIS PHONE . just switch phone to PDA ( *#7284# ) Select T989 model. Connect phone with UART , and click unlock . Code: Count supported models - 315 Reading Phone Info... OK Build: M8960A-AAAANAZM-1.0.442802 IMEI: 353091050576471 Reading Security... OK Calculating... OK Unlocking ... OK Done with Samsung Tool ver 12.6 LITTLE MASTER |
The Following User Says Thank You to Little_Master For This Useful Post: |
07-16-2012, 08:32 | #15 (permalink) | |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
