How to unlock the i747 with z3x ? is possible to unlock the north america version of the i9300 galaxy s3 i747 with z3x ? thank you ! |
Nope not yet. Apparently the T999 could be unlocked as T989 though via Z3x (make sure the phone is rooted) |
i am also looking to unlock i747 |
no solution for I747m with Z3X just w8 and we are waiting |
i747 done with T999 model i747 done with T999 model: Checking Phone On COM4... OK Reading Phone Info... OK Build: M8960A-AAAANAZM-1.0.442802 IMEI: 353091050056094 Done with Samsung Tool ver 12.6 Reading Phone Info... OK Build: M8960A-AAAANAZM-1.0.442802 IMEI: 353091050056094 Reading Security... OK Calculating... OK Unlocking ... OK Done with Samsung Tool ver 12.6 BillA |
Dear BillA Quote:
after typing * # 9090 # usb choose which ones that? thank you very much, I have installed the usb port but not search phone. again thank a lot!. I look forwards to hearing from you. Regards, |
I got same phone as well. Its rooted, \With UART cable it says " Code: Reading Phone Info... OK Code: Searching Samsung USB Modem... Detected (COM212) LITTLE MASTER |
i747m confirm unlock with z3x 12.6 this is what i did: Code: 1. Connect phoen to PC powered via USB and enter MTP mode (Media Transfer) and this is my unlock log: Code: -------------------------- 14.7.2012_10-31-9 -------------------------- |
@_mo_ you can skip rooting for phones unlock over qc mode. rooting for unlocking is useless all this phones. basic info for all. I727,I727M,T989,T989D,T999,I747,I747M,T769 many other etc unlock in qualcomm mode. if modem is set on uart use uart cable for unlocking & repairing. if modem is set to usb use usb cable for unlocking & repairing. use this two codes to set need port setting. *#7284# *#9090# some phone like I747M have switching blocked(can't select),so people can use (*2767*3855#) to full reset phone then you can set it. Regards, Chevli |
thank you for the heads up - i did try without rooting but kept failing. i rooted and it went straight through. i will try again with another one withour rooting thank you |
I feel what austin has said is correct, rooting is not necessary. Since the moment you perform a factory reset, using the above command root is lost. You were still able to unlock your phone, this implies that the root is not required. I welcome to be corrected. |
yes thats right - second piece went through without root - how odd |
unlock done UNLOCK DONE. ROOTING NOT NEEDED FOT THIS PHONE . just switch phone to PDA ( *#7284# ) Select T989 model. Connect phone with UART , and click unlock . Code: Count supported models - 315 LITTLE MASTER |
