Old 07-01-2012, 05:26   #1 (permalink)
Member: 114443
Thanks Meter: 6
How to unlock the i747 with z3x ?
is possible to unlock the north america version of the i9300 galaxy s3 i747 with z3x ?
thank you !
Old 07-01-2012, 18:29   #2 (permalink)
Member: 84323
Thanks Meter: 15
Nope not yet.
Apparently the T999 could be unlocked as T989 though via Z3x (make sure the phone is rooted)
Old 07-05-2012, 00:07   #3 (permalink)
<:SAQI:>'s Avatar
Member: 1599578
Sonork: 8114214
Thanks Meter: 131
i am also looking to unlock i747
Old 07-07-2012, 04:24   #4 (permalink)
ansari123's Avatar
Member: 292789
Thanks Meter: 636
no solution for I747m with Z3X
just w8 and we are waiting
The Following User Says Thank You to ansari123 For This Useful Post:
Old 07-12-2012, 13:44   #5 (permalink)
Member: 92260
Thanks Meter: 843
i747 done with T999 model
i747 done with T999 model:
Checking Phone On COM4... OK
Reading Phone Info... OK
Build: M8960A-AAAANAZM-1.0.442802
IMEI: 353091050056094
Done with Samsung Tool ver 12.6
Reading Security... OK
Calculating... OK
Unlocking ... OK
BillA
Old 07-12-2012, 19:07   #6 (permalink)
Member: 885342
Sonork: congthanh211
Thanks Meter: 7
Dear BillA
Searching Samsung USB Modem... Not Found
Calculating... OK
Unlocking ... OK
Please, let me ask t999 and i747 galaxy s3 model to use and select z3x to unlock it on that?
after typing * # 9090 # usb choose which ones that?
thank you very much,
I have installed the usb port but not search phone. again thank a lot!.
I look forwards to hearing from you.
Regards,
Old 07-14-2012, 08:58   #7 (permalink)
Little_Master's Avatar
Member: 1205146
Thanks Meter: 879
I got same phone as well.
Its rooted,
\With UART cable it says "
IMEI:  000000000000000
Reading Security... Error
with USB Cable it just read phone info, but doesn't detect it to unlock
Searching Samsung USB Modem... Detected (COM212)
Model:  SAMSUNG-SGH-I747
IMEI:  I747UCLEM
LITTLE MASTER
Old 07-14-2012, 12:00   #8 (permalink)
Member: 65097
Sonork: 100.111703
Thanks Meter: 7
i747m confirm unlock with z3x 12.6
this is what i did:
1. Connect phoen to PC powered via USB and enter MTP mode (Media Transfer)
2. Copy 'SuperUser.zip' to the root of Internal Storage
3. Power off phone and go into Download Mode (Volume Down + Home + Power -- Then press Volume Up to continue)
4. Open Odin 1.85+
5. Add 'RecoveryGalaxyS3USCanada.tar' into PDA and flash
6. As soon as flash finishes - remove battery
7. Reinsert battery and enter recovery mode (Volume Up + Home + Power -- Only hold power for around 3 seconds)
8. Once in recovery, select 'install zip from sdcard' then 'choose zip from internal sdcard'
9. Next select 'SuperUser.zip' and confirm
10. Once you get 'Install from sdcard complete' go back and reboot and root should be complete.
11. once restarted - do a full reset (*2767*3855#)
12. *#7284# - select modem
13. *#9090# - select USB and reboot phone
14. Make sure device is in USB Debugging mode and connect with C3300k cable directly to z3x.
15. open Samsung Tool 12.6 and select T989 as model and select COM for box and press unlock.
You can download from here: http://www.freeiphone4.me/i747mSU.zip
and this is my unlock log:
-------------------------- 14.7.2012_10-31-9 --------------------------
Count supported models - 315
IMEI:  ***********2467
Calculating... OK
Unlocking ... OK
The Following User Says Thank You to _mo_ For This Useful Post:
Old 07-14-2012, 12:24   #9 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,085
@_mo_
you can skip rooting for phones unlock over qc mode.
rooting for unlocking is useless all this phones.
basic info for all.
I727,I727M,T989,T989D,T999,I747,I747M,T769 many other etc unlock in qualcomm mode.
if modem is set on uart use uart cable for unlocking & repairing.
if modem is set to usb use usb cable for unlocking & repairing.
use this two codes to set need port setting.
*#7284#
*#9090#
some phone like I747M have switching blocked(can't select),so people can use (*2767*3855#) to full reset phone then you can set it.
Regards,
Chevli
The Following User Says Thank You to stanner_austin For This Useful Post:
Old 07-14-2012, 13:02   #10 (permalink)
Member: 65097
Sonork: 100.111703
Thanks Meter: 7
thank you for the heads up - i did try without rooting but kept failing.
i rooted and it went straight through.
i will try again with another one withour rooting
thank you
Old 07-14-2012, 13:26   #11 (permalink)
Member: 1002949
Sonork: 100.1582346
Thanks Meter: 273
Originally Posted by stanner_austin View Post
@_mo_
basic info for all.
*#7284#
*#9090#
Regards,
Chevli
qc mode = qualcomm mode?
Old 07-14-2012, 14:09   #12 (permalink)
Member: 1773961
this is what i did:
4. Open Odin 1.85+
Calculating... OK
Unlocking ... OK
I feel what austin has said is correct, rooting is not necessary. Since the moment you perform a factory reset, using the above command root is lost. You were still able to unlock your phone, this implies that the root is not required. I welcome to be corrected.
Old 07-14-2012, 16:25   #13 (permalink)
Member: 65097
Sonork: 100.111703
Thanks Meter: 7
yes thats right - second piece went through without root - how odd
Old 07-15-2012, 01:38   #14 (permalink)
Member: 1205146
Thanks Meter: 879
unlock done
UNLOCK DONE.
ROOTING NOT NEEDED FOT THIS PHONE .
just switch phone to PDA ( *#7284# )
Select T989 model.
Connect phone with UART , and click unlock .
IMEI:  353091050576471
Calculating... OK
Unlocking ... OK
LITTLE MASTER
The Following User Says Thank You to Little_Master For This Useful Post:
Old 07-16-2012, 08:32   #15 (permalink)
Member: 1002949
Sonork: 100.1582346
Thanks Meter: 273
@_mo_
basic info for all.
*#7284#
*#9090#
Regards,
Chevli
pleasse confirm sir qc= qualcomm
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Page generated in 0.29611 seconds with 9 queries
