06-02-2011, 10:16 | #2 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Gujranwala Pakistan Age: 48
Member: 71190 Status: Offline Sonork: 100.1580485 Thanks Meter: 87 | slect e2330 in z3x use e210 usb cable and read codes here is log: Selected model: E2330 Selected com port: COM12 Selected speed port: 921600 Phone must be OFF Press * and connect phone by cable Connecting to Device... OK Wait for decrypted code... OK Decrypted time: 81 sec [PCK]:#0141*00000000# [NCK]:#0111*47137872# [SCK]:#0121*00000000# [SPCK]:#0133*00000000# [MCK]:#0199*93891246# Read info - ok Elapsed time: 100 second, sw ver: 3.5.0018 |
The Following User Says Thank You to nobal1976 For This Useful Post: |
10-18-2012, 13:04 | #3 (permalink) |
Freak Poster Join Date: Sep 2011
Member: 1652459 Status: Offline Thanks Meter: 22 | select e2330 in z3x use e210 usb cable and read codes if not work, try with safe mode. In my case working,with safe mode, here you have log: Selected model: E2330 Selected com port: COM4 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Damping ... OK Calculated code please wait... Decrypted time: 54 sec This is zone 0 [PCK]:Enter this without sim #0141*00000000# this is sim lock [NCK]:Enter this without sim #0111*1342xxxx# this is net lock [SCK]:Enter this without sim #0121*00000000# this is CP lock [SPCK]:Enter this without sim #0133*00000000# this is SP lock [MCK]:Enter this without sim #0199*9621xxxx# this is Master(freeze) code safe read info - ok Elapsed time: 141 second, sw ver: 3.5.0038 |
12-09-2012, 16:45 | #4 (permalink) |
Junior Member Join Date: Oct 2011 Location: Germany Düsseldorf
Member: 1677667 Status: Offline Sonork: janjua28 Thanks Meter: 0 | i have this problam someone halep me.............. Selected model: E2230 Selected com port: COM7 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Damping ... OK Erasing ... OK Writing ... OK After power on phone - connect to UART cable Timeout Deactivate MSL - fail Read info - fail Elapsed time: 70 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- |
12-10-2012, 19:29 | #5 (permalink) | |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | Quote:
BR. Arsalan gsm2000. | |
12-11-2012, 10:07 | #6 (permalink) |
Freak Poster Join Date: Dec 2004 Location: ROMANIA Age: 45
Member: 99768 Status: Offline Thanks Meter: 35 | Why don't u read carrefully the first post? Whe are talking about Samsung E2230 (E210 usb pinout) and not about E2330 (C3300 micro USB connectot). The USB connector is not the same at these models. Regards! |
12-15-2012, 19:46 | #7 (permalink) |
Junior Member Join Date: Sep 2005
Member: 178186 Status: Offline Thanks Meter: 2 | If you see "Not Yet personalised": Insert not accepted sim, enter subset lock [SCK] and will see "Personalisation canceled" On NsPro is "subset lock" or on Z3X is [SCK] or CP lock. #0121*subset lock code# |
02-12-2013, 20:02 | #10 (permalink) | |
Freak Poster Join Date: Jul 2006
Member: 314780 Status: Offline Thanks Meter: 12 | Quote:
Elapsed time: 8 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- Selected model: E2330 Selected com port: COM10 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Damping ... OK Calculated code please wait... Decrypted time: 5 sec This is zone 0 [PCK]:Enter this without sim #0141*00000000# this is sim lock [NCK]:Enter this without sim #0111*00000000# this is net lock [SCK]:Enter this without sim #0121*00000000# this is CP lock [SPCK]:Enter this without sim #0133*00000000# this is SP lock [MCK]:Enter this without sim #0199*00000000# this is Master(freeze) code safe read info - ok Elapsed time: 128 second, sw ver: 3.5.0040 ----------------------- | |
03-14-2013, 16:58 | #11 (permalink) |
No Life Poster Join Date: Nov 2003 Location: Romania/Craiova Age: 44
Member: 44085 Status: Offline Thanks Meter: 123 | After 1000 tries: Code: Selected model: E2330 Selected com port: COM7 Selected speed port: 460800 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Damping ... OK Calculated code please wait... Decrypted time: 41 sec This is zone 0 [PCK]:Enter this without sim #0141*00000000# this is sim lock [NCK]:Enter this without sim #0111*95605650# this is net lock [SCK]:Enter this without sim #0121*00000000# this is CP lock [SPCK]:Enter this without sim #0133*00000000# this is SP lock [MCK]:Enter this without sim #0199*64903187# this is Master(freeze) code safe read info - ok Elapsed time: 127 second, sw ver: 3.5.0040 |
04-16-2013, 10:12 | #12 (permalink) |
Freak Poster Join Date: Dec 2008
Member: 921420 Status: Offline Thanks Meter: 28 | what u need to do:... after ****in' up the IMEI tried to repair it with "Custom"...didn't work so... i've selected E2350 and... OTP repair... Selected model: E2350 Selected com port: COM3 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Erasing ... OK Writing ... OK Repair OTP - ok Elapsed time: 17 second, sw ver: 3.5.0040 THEN IMEI repai with "Custom"... Selected model: E2350 Selected com port: COM3 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Damping ... OK Erasing ... OK Writing ... OK Search diag port... OK (COM26) Phone SN: RV1D10YZXQ Deactivate MSL - OK Phone OLD IMEI: 35704204597955/00 Repair - fail Elapsed time: 49 second, sw ver: 3.5.0040...it says repair fail but it lies like a motha****a and then READ codes... Selected model: E2350 Selected com port: COM3 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Damping ... OK Erasing ... OK Writing ... OK Search diag port... OK (COM26) Phone SN: RV1D10YZXQ Deactivate MSL - OK Calculated code please wait... Decrypted time: 94 sec This is zone 0 [PCK]:Enter this without sim #0141*00000000# this is sim lock [NCK]:Enter this without sim #0111*42097239# this is net lock [SCK]:Enter this without sim #0121*00000000# this is CP lock [SPCK]:Enter this without sim #0133*00000000# this is SP lock [MCK]:Enter this without sim #0199*49798944# this is Master(freeze) code Read info - ok Elapsed time: 141 second, sw ver: 3.5.0040 i've only used the usb cable |
06-01-2013, 09:51 | #13 (permalink) |
Junior Member Join Date: Mar 2010 Location: Romania Age: 43
Member: 1253967 Status: Offline Thanks Meter: 2 | E2230 unlock standard USB cable, press and hold *, select model E2530, press SAFE INFO button Selected model: E2530 Selected com port: COM3 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Damping ... OK Calculated code please wait... Decrypted time: 30 sec This is zone 0 [PCK]:Enter this without sim #0141*00000000# this is sim lock [NCK]:Enter this without sim #0111*3426XXXX# this is net lock [SCK]:Enter this without sim #0121*00000000# this is CP lock [SPCK]:Enter this without sim #0133*00000000# this is SP lock [MCK]:Enter this without sim #0199*31756935# this is Master(freeze) code safe read info - ok Elapsed time: 119 second, sw ver: 3.5.0040 |
The Following User Says Thank You to albinutza For This Useful Post: |
06-07-2013, 12:14 | #14 (permalink) | |
Junior Member Join Date: Dec 2010 Location: Bucuresti Romania
Member: 1469112 Status: Offline Sonork: lacramioru Thanks Meter: 1 | Quote:
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
