How to unlock Samsung GT-I9100 Z3X-Team First: UART and USB settings: enter UART mode with *#9090# and select "Log via UART" then enter *#7284# and select "UART MODEM" and select "USB PDA". Now Windows ask normal samsung drivers! Then: -power on phone -go to MENU==>SETTING==>APPLICATIONS==> DEVELOPEMET check USB DEBUGGING -connect phone using USB then wait till driver is installed Then: put UNLOCK(root) select port then click UNLOCK then wait... ROOTING the phone Then: Unlock DONE http://img850.imageshack.us/img850/5125/dibujovj.jpg |
just wait |
1 Attachment(s) Quote:
thanks it work ok and thanks to z3x team |
Code: gooooooooddddd and nice |
how to remove pattern lock on i9100 pattern lock on i 9100 once switch on.how to remove with z3x? |
thank's z3x-team great work |
Thank's It work ok--------------- |
Count supported models - 290 Searching Samsung USB Modem... Detected (COM7) Model: GT-I9100 SW: I9100NEKI2 IMEI: 35958xxxxxxxxxx Starting ADB Server... OK Checking ROOT... FALSE Reading Phone Info... OK Android Version: 2.3.5 Model: GT-I9100 Product Code: GT-I9100LKAH3G Phone Version: I9100NEKI2 PDA Version: I9100XWKI8 CSC Version: I9100H3GKI2 IMEI: 35958xxxxxxxxxx Rooting Phones... OK Reading Data From Phone... OK Writing NV Data To Phone... OK Calculating md5... OK Writing md5 To Phone... OK Rebooting... OK Done with Samsung Tool ver 11.9 |
It work Thank's ------------------- |
i9100 pattern remove how do you uart the phone? because once switched on it immediately asks for the pattern unlock |
just follow mr1x instructions and it will work |
@gji25: How will it work,if cannot type anything??? |
you type it into the phone keypad on the screen.. and if you cant.. why ? |
thanks it work ok and nice to z3x team |
