05-02-2013, 07:42 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: CLOUD Age: 40
Member: 486357 Status: Offline Sonork: 100.1602846 Thanks Meter: 1,220 | How to unlock samsung i957 micro-uart cable: 1. Phone must be powered on. 2. Connect the phone to UART port. 3. Choose correct COM port in port settings. 4. Press "Unlock" button. micro-USB cable: 1. Phone must be powered on. 2. Type *#7284# and choose Modem for both options. 3. Type *#9090# and choose USB Diag. 4. Reboot phone. 5. Connect USB cable, install drivers. 6. Select diagnostic port in port settings. 7. Press "Unlock" button. there is no dial paid after connect usb cable show 2 com port here is info elected model: I957 Selected port: COM4 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Reading phone info... fail Done with Samsung Tool v.14.3 Selected model: I957 Selected port: COM41 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... Reading phone info... fail Done with Samsung Tool v.14.3 Selected model: I957 Selected port: COM73 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... Reading phone info... fail Done with Samsung Tool v.14.3 Done with Samsung Tool v.14.3 |
05-02-2013, 07:51 | #2 (permalink) | ||
No Life Poster Join Date: Jul 2011 Location: ۞_ KERALA__۞_INDIA
Member: 1619462 Status: Offline Sonork: 100.1606509 Thanks Meter: 1,517 | Quote:
05-02-2013, 07:54 | #3 (permalink) |
Freak Poster Join Date: Mar 2013
Member: 1896297 Status: Offline Sonork: 125050 Thanks Meter: 182 | i m conect me [email protected] |
05-02-2013, 08:35 | #5 (permalink) | ||
Try Like This.. Quote:
05-13-2013, 14:13 | #8 (permalink) |
Member: 486357 Status: Offline Sonork: 100.1602846 Thanks Meter: 1,220 | unlock Done after update SGH-I957_ATT_I957UCLK4_I957ATTLK4_Original this rom Enable phone keypad Go to Applications > Utility > Calculator For Android 3.x type: (+32286798378+ For Android 4.x type: (+30012012732+ Change phone mode Go to the keypad and type *#7284# Select MODEM option at the USB section. If the code does not work, use *#9090# instead. Go to the keypad and type *#1575# Now press the MENU key, select Back, [4] DIAG CONFIG and select the [1] USB option. Press the MENU key and select END. Now restart your phone and wait until it fully starts up. Selected model: I957 Selected port: COM19 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... PDA/CSC version: I957UCLK4/I957ATTLK4 Phone version: SW VERSION :None Phone HW: REV0.1 Cal date: 2012.01.26 IMEI: 35844404056911 Phone S/N: R31C10RBJ4 Build: M9200B-SCAQCSZD-3.4.701100 Reading security... OK Searching server... OK NET lock: #7465625*638*83730853# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung Tool v.14.3 |
The Following User Says Thank You to mohit_kripalu01 For This Useful Post: |
