Old 08-26-2011, 09:51   #46 (permalink)
Member: 1486828
Sonork: pcs1234
Thanks Meter: 53
My solution that works for me ,unlocking S5620
1.tool 3.5.0026 uart 3300k cable
2.connect uart cable to phone without battery,press read info(codes)
3.when says searching phone
4.slide battery into phone ,and will give you codes,ive never flashed any of these phones to get codes. ive done 4 phone this way ,all worked,hope this helps someone
5.put different sim in and enter code .....
my last log
--------------------------- 24/08/2011 15:08:20 -----------------------------
Selected model: S5620
Selected com port: COM5
Selected speed port: 921600
For this algoritm use micro UART cable !
Phone must be OFF
Search phone... OK
Download phone loader... OK
Wait for download mode... OK
Authorization... OK
Please wait decrypt code ... OK
[FREZEE]:49415935
[NET LOCK]:52096062
[Subset LOCK]:00000000
[SP LOCK]:00000000
[CP LOCK]:00000000
Decrypted time: 21 sec
Elapsed time: 71 second, sw ver: 3.5.0026
The Following 2 Users Say Thank You to pcs1234 For This Useful Post:
Old 08-30-2011, 15:57   #47 (permalink)
Member: 159541
use rj45 cable of z3x and press read code.........no need to flash d phone for unlock.
Old 09-06-2011, 18:08   #48 (permalink)
Member: 1486828
Sonork: pcs1234
Thanks Meter: 53
ive never had to flash phone with this method ,works for me every time ..
Old 09-09-2011, 19:22   #49 (permalink)
unlockmachine44's Avatar
Member: 1350724
Thanks Meter: 188
hi
do we sitl need to flash teh phone to unlock it?
thanks
Old 09-09-2011, 19:33   #50 (permalink)
:Aishur:'s Avatar
Member: 1315677
Thanks Meter: 1,439
Originally Posted by killa76 View Post
hi
thanks
follow the instructions(red frame)
when you see "search phone"
insert the cable
Old 09-09-2011, 19:45   #51 (permalink)
Member: 1350724
Thanks Meter: 188
did not work for me i am flashing the phone we need real solution from z3x team
Old 02-24-2012, 12:50   #52 (permalink)
Crazy Poster
Member: 80729
Thanks Meter: 5
insert the cable
worked lika a charm . thnx
Old 03-13-2012, 19:12   #53 (permalink)
Member: 85467
Thanks Meter: 104
hello
i have'nt luck:
Selected com port: COM3
Phone must be OFF
Search phone... Fail !
Elapsed time: 16 second, sw ver: 3.5.0035
try also with ver 026/027/030.. the same
must flash phone?
thx
Old 03-23-2012, 03:34   #54 (permalink)
Member: 1724900
hi my phone is not working now ... keep turn on and off and loading bar at the bottom ...
thanks
Old 03-23-2012, 08:34   #55 (permalink)
minkoi's Avatar
Member: 55342
Sonork: 100.1619358
Thanks Meter: 281
thanks
flash vith multiloader(full flash&boot)...........
Old 03-23-2012, 13:52   #56 (permalink)
Member: 436600
Thanks Meter: 67
s5620 no need flash to unlock
Old 06-04-2012, 22:24   #57 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 792
after many unsuccessfull tries I did mine with microbox
Old 06-05-2012, 07:27   #58 (permalink)
ZiDanRO's Avatar
Member: 1722871
Thanks Meter: 116
Maybe you dont use the right cabel. You need to use C3300K Cabel and nothing else.
This are the steps to unlock S5620:
1. Power off the phone
2. Select in z3x shell S5620 model and -> Run
3. Connect rj45 conector of C3300k cable to z3x box. But NOT the micro-usb to the phone
4. Push "Read Codes" button from z3x aplication
5. Now connect the micro-usb to the swithced off phone and wait to do his work
6. And you have the codes to unlock the phone
Selected com port: COM25
Phone must be OFF
Search phone... OK
Authorization... OK
[FREZEE]:26846391
[NET LOCK]:90941917
[SP LOCK]:00000000
[CP LOCK]:00000000
Decrypted time: 49 sec
Elapsed time: 101 second, sw ver: 3.5.0037
If it dosent work from the first time, try again.
Old 06-14-2012, 15:42   #59 (permalink)
Member: 1317020
Sonork: 100.1616949
Thanks Meter: 19
pls help after flashing phone is on blank green display only . any solution .phone s5620 . thanks in adv ,
Old 07-12-2012, 04:50   #60 (permalink)
.:Sanjh Phoenix:.'s Avatar
Member: 1728736
Sonork: 100.1615042
Thanks Meter: 1,098
Thumbs up No need down loader no need to take headache to flashing s5620
only do this
10000000000% solve
Advantage
The Following User Says Thank You to .:Sanjh Phoenix:. For This Useful Post:
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 22:36
Page generated in 0.21114 seconds with 9 queries
