12-08-2016, 08:14 | #1 (permalink) |
Freak Poster Join Date: Apr 2014 Location: Pakistan
Member: 2170171 Status: Offline Sonork: 100.1652359 Thanks Meter: 30 | how to unlock Sm-n900j Activate Diagnostic Port: 1. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Select device in ADB settings. 2. Press 'Activate Diag' button. Reset EFS, Disable Factory Mode: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. 6. If you have yellow table on your device screen, then press 'Disable Factory Mode' button. Wipe EFS/NVM: If you have 'IMEI null/null' or 'Phone baseband unknown' errors, Then you can try to repair this errors with this function. 1. Power on phone in download mode (turn off phone, hold Volume Down + Home + Power). 2. Connect USB cable, install drivers if needed. 3. Press 'Wipe EFS/NVM' button to deactivate security. 4. Wait till phone reboot. Operation: Activate DIAG Selected model: SCL22 Selected port: COM1 Communications Port Software version: 27.3 Waiting ADB device... Ok Reading phone info... Model: SM-N9005 Android version: 5.0 Product code: Not Active Phone version: SCL22KDU2FNF7 PDA version: N9005XXU2COH7 CSC version: CSC country code: JP CSC sales code: KDI HW version: N900J.09 Phone SN: 00000000000 Modem board: MSM8974 RF cal date: 2014.06.25 IMEI: Operation aborted Done with Samsung Tool PRO v.27.3 |
