10-03-2012, 10:43 | #1 (permalink) |
No Life Poster Join Date: Nov 2008
Member: 901472 Status: Offline Thanks Meter: 48 | i cant read phone info i already done write efs with riffbox now need to read info check imei is 0049xxx or not and keep Searching Samsung USB Modem... Not Found pls help |
10-03-2012, 20:09 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Tunisia
Member: 261437 Status: Offline Sonork: no Thanks Meter: 922 | First check your cable Enable debuging mode in phone options see here http://forum.gsmhosting.com/vbb/atta...4&d=1336144352 http://forum.gsmhosting.com/vbb/f453...3-6-a-1469913/ http://forum.gsmhosting.com/vbb/f453...-done-1490802/ 1. Power on phone. 2. Enable debugging on: menu>application settings>development.. 3. Connect cables and setup drivers. 4. Press Unlock SP button. Last edited by noure30; 10-03-2012 at 20:17. |
10-03-2012, 23:21 | #4 (permalink) |
Freak Poster Join Date: Sep 2011 Location: In The World Of ALLAH & RASOOL Age: 33
Member: 1647655 Status: Offline Sonork: 100.1640928 Thanks Meter: 50 | Try uart cable if that dose not work then make sure you have firmware 2.3.3 or 2.3.4 then unable debugging and try it again. |
10-04-2012, 18:25 | #6 (permalink) |
No Life Poster Join Date: Sep 2010 Location: In trouble Age: 49
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | Just to read info about your phone, no need anything else than usb cable. Just enable usb debugging in your phone, connect it and click on unlock. It will show you all you need to know |
