02-03-2013, 04:12 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Cuba Age: 56
Member: 517318 Status: Offline Thanks Meter: 88 | I cant unlock Samsung S7500L Telcel I'm trying to unlock this phone from Telcel, did full flash, I read codes, the income and tells me that the code is incorrect, direct unlock and still blocked. * # 7465625 # are all locks off and continued asking network code, did full reset. Do not know what else to do to unlock it, if someone could help me. Thanks in advance. mfeliu07 |
02-03-2013, 11:39 | #2 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Quote:
The Following User Says Thank You to pradeep_kus For This Useful Post: |
02-03-2013, 11:55 | #3 (permalink) |
Freak Poster Join Date: Dec 2010 Location: Inside the Box, Panama Age: 34
Member: 1468994 Status: Offline Thanks Meter: 27 | this remember me when i tried to unlock a M3710 from the same carrier, everything the same symptoms as you describe, to successful unlock i have to flash the BOOT only via UART and then full flash without BOOT, after all everything working ok.. at my job, i have to flash the BOOT to some cellphones, so i can successful unlock if u can try, flashing the BOOT with no problems, i thing you can unlock that cellphone |
The Following User Says Thank You to carlosm15 For This Useful Post: |
02-03-2013, 12:07 | #4 (permalink) | |
02-03-2013, 15:17 | #5 (permalink) |
Member: 517318 Status: Offline Thanks Meter: 88 | Hi, thanks for help. I commented: 1-update with Odin 1.87 boot without the PIT (which is not used) 2 - flash without boot. 3-Direct unlock (The codes are in 00000000.) 4-Keep asking network code and appear in all the locks off. I can not think what else I can do. Any idea? Thank you. mfeliu07 |
02-03-2013, 15:53 | #6 (permalink) | |
And Joine Me I'll Chk | |
02-03-2013, 17:44 | #7 (permalink) | |
Member: 517318 Status: Offline Thanks Meter: 88 | Have version 2.3.6 of Android Quote:
02-04-2013, 14:37 | #8 (permalink) | |
Member: 517318 Status: Offline Thanks Meter: 88 | Hello Any suggestions? Greetings. mfeliu07 Quote:
08-07-2013, 20:29 | #11 (permalink) | |
Junior Member Join Date: Jun 2008
Member: 801726 Status: Offline Sonork: angycargsm Thanks Meter: 2 | unlock s7500_telcel_done_steps Quote:
use this flash: S7500LVJLH1_S7500LVJLG3_S7500LCHELG1_HOME.tar.md5 ... I assure you 100% that you will be ok .. P.D. sorry but I am using the English translator, I hope I do understand ... regards | |
The Following User Says Thank You to angycargsm For This Useful Post: |
08-07-2013, 22:31 | #12 (permalink) | |
Member: 517318 Status: Offline Thanks Meter: 88 | Thanks for your answer, solve the probleme as I said in the last post. Regards Quote:
09-28-2013, 18:41 | #13 (permalink) | |
Junior Member Join Date: Sep 2013
Member: 2035914 Status: Offline Sonork: hola buen dia Thanks Meter: 0 | as I get my phone system Quote:
I am in cwm screen-based recovery V5.0.2.8 samsumg gt-S7500L como recupero mi sistema del telefono apli el codigo *2767*3855# y se reinicio estoy en la pantalla de cwm-based recovery V5.0.2.8 samsumg gt -S7500L | |
