11-20-2014, 15:38 | #1 (permalink) |
Freak Poster Join Date: Feb 2004 Location: noWhere Age: 45
Member: 52810 Status: Offline Thanks Meter: 19 | i need SM-G900T efs backup i lost baseband while unlocking sm-g900t i have no backup for this device please help a backup using efs professional would be a good help. thanks in advance |
11-20-2014, 21:59 | #3 (permalink) |
Member: 52810 Status: Offline Thanks Meter: 19 | thats maybe right when the device still have baseband, but i got unknown baseband I mean that autobackups are useless, it doesnt have efs backup its only nvm backup. thanks, and i still need a g900t efs backup |
11-20-2014, 22:14 | #4 (permalink) |
Banned Join Date: Nov 2013 Location: Chicago, IL
Member: 2076039 Status: Offline Thanks Meter: 648 | Have you TRIED to load the backup? AFAIK, it has everything you need for a corrupted baseband. If it's still corrupted afterwards you're going to need to wipe the EFS again (manual way through ADB). Either that or your modem partition is damaged or your hardware is damaged. |
11-20-2014, 23:42 | #5 (permalink) |
Member: 52810 Status: Offline Thanks Meter: 19 | how to load the backup? there is no such thing restore backup. it only restores it through the wipe efs process, which i cannot apply after the unknown baseband. and the .tar backup which created does not have an efs.img.ext* file which i need. it only has nvrebuild1 and 2 files please help. |
11-21-2014, 00:35 | #6 (permalink) |
Member: 2076039 Status: Offline Thanks Meter: 648 | Pretty sure you can write the QCN that was backed up. I'm pretty sure your efs folder/partition is fine. I've seen phones with NO efs folder and they work fine. This isn't the days of the S2 where your EFS really was in the EFS partition folder. Now they're spread across 3 partitions that have absolutely nothing to do with the EFS partition/folder. Try writing your QCN. If that doesnt work, I have a homebrew surprise that might fix the issue (an adb script). |
11-23-2014, 14:27 | #8 (permalink) |
Member: 52810 Status: Offline Thanks Meter: 19 | i fixed that, i created a backup from g900f includes this /modem /efs /nvrebuild1 /nvrebuild2 i wrote it to the broken one i got modem warning at boot up i flashed stock rom then i got working baseband but with a restart problem for unauthorized something .. then i flashed back the backup files created by z3x using odin, which contains nvrebuild1 and nvrebuild2 now phone back to the original status with original imei and network locked. |
