04-23-2014, 07:45 | #2 (permalink) |
No Life Poster Join Date: Mar 2013 Location: pakistan Age: 34
Member: 1899191 Status: Offline Sonork: 100.1625109 Thanks Meter: 136 | micro-uart cable: 1. Phone must be powered on. 2. Connect the phone to UART port. 3. Choose correct COM port in port settings. 4. Press "Unlock" button. micro-USB cable: 1. Phone must be powered on. 2. Type *#7284# and choose Modem for both options. 3. Type *#9090# and choose DM\DUM over HS-USB. 4. Reboot phone. 5. Connect USB cable, install drivers. 6. Select diagnostic port in port settings. 7. Press "Unlock" button. (unlocking writting the same IMEI) In phone type: *#0808# select AP -> DM+MODEM+ADB (click OK) open Z3X select I337, and select COM Port'X' Z3X Box Serial Port, connect phone with USB go to repair: choice repair EFS/Baseband, fill imei and choise imei, click OK. Selected model: I337 Selected port: COM9 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: SAMSUNG-SGH-I337 Android version: 4.2.2 Product code: Not Active Phone version: I337UCUAMF3 PDA version: I337UCUAMF3 CSC version: I337ATTAMF3 IMEI: 0 spent 1ms Phone S/N: R31D515Z7YY Checking Super user right... true Writing data to phone... OK Rebooting phone... OK Checking phone at COM9 OK ------>In this moment disconnect from USB, connect with UART C3300K. Repairing IMEI... OK Reseting... OK Repair done Done with Samsung Tool v.16.8 Note: Phone will be rooted (with impactor, I guess). At some point you have to go to the phone and give permission. (on rooting, and IMEI repair/unlock) PC: W7 64 Bits |
04-24-2014, 13:29 | #6 (permalink) |
Banned Join Date: Mar 2014
Member: 2151956 Status: Offline Thanks Meter: 6 | People actually trust you with their $700 dollar phones? Why would you root the phone. Just downgrade the modem to any i337 4.2.2 modem and use z3x version 16.9. After operation flash original modem back. I mean this is basic knowledge. G0D forbid you have to learn how to extract a modem from a rom using linux...LoL |
04-24-2014, 15:17 | #8 (permalink) |
Junior Member Join Date: Dec 2013
Member: 2082540 Status: Offline Sonork: iffiji Thanks Meter: 0 | Mobile Unlock Boxes 4 pieces, ZX3, ATF Turbo, Volcano and SE Tool box brand new unused with original packing and cables. Bought few months before but did not used, scratchless, untouched. Interested person may contact. Could be slightly discount only. |
05-03-2014, 15:16 | #9 (permalink) |
No Life Poster Join Date: Nov 2005 Location: 46000
Member: 197566 Status: Offline Thanks Meter: 89 | I check this method If I337 NB1 version need downgrade. NB1►DOWNGRADE 1. PIT file 2. Firmware MK2 3. ODIN 1. Download all three files above 2. Open ODIN3v3.09 3. Load both Pit and AP together to corerct slot ( Pit >>PIT SLOT.....AP>>PDA SLOT ) and hit start..... 5. When is done....reboot to stock recovery and choose Full Wipe/Factory Reset. 6. Root using Saferoot Method When do unlock with checked new security. Last edited by trt; 05-03-2014 at 15:24. |
