08-22-2014, 09:38 | #1 (permalink) |
Freak Poster Join Date: Jul 2012 Location: hole
Member: 1784040 Status: Offline Thanks Meter: 32 | i747 error appeared in screen... I received i747 from my customer with error appeared in screen see attched below pls. And i did flash any firmware already but error not remove, anybody here can help to solve dis will appreciated. |
08-22-2014, 16:24 | #4 (permalink) |
Freak Poster Join Date: Mar 2014 Location: United States
Member: 2146046 Status: Offline Thanks Meter: 62 | 100% Easy Fix ! Done this many times to fix this issue 1. Click Z3X Repair Option to "Disable Test Mode" AKA Factory Mode (This is what is on your screen in picture) 2. Check DISABLE TEST MODE 3. CHECK IMEI and fill in your IMEI in case Z3X decides to set it to "0" 4. You shouldn't have to CHECK "Reset EFS" but if it errors out or doesn't work try checking RESET EFS as well. 5. HIT OK and let Z3X Repair and Disable Test Mode! Give me a thanks if this helped! |
The Following User Says Thank You to GTrader For This Useful Post: |
08-23-2014, 10:52 | #5 (permalink) | |
Member: 1784040 Status: Offline Thanks Meter: 32 | Quote:
09-04-2014, 08:41 | #6 (permalink) | |
Junior Member Join Date: Oct 2010
Member: 1408398 Status: Offline Sonork: IUA Thanks Meter: 2 | Quote:
09-09-2018, 05:05 | #7 (permalink) |
Freak Poster Join Date: Jul 2016 Location: Chile Age: 41
Member: 2601431 Status: Offline Thanks Meter: 35 | I tried everything in the web and nothing worked. My solution: Root the i747 with kingoroot, it will install a application that will allow you to uninstall system app, uninstall factory test (I think they are 2) and Test mode (I don't remember the name properly). Reboot the phone and the fcking yellow letters will be gone. |
