10-20-2014, 12:33 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: india
Member: 588837 Status: Offline Thanks Meter: 146 | i747 s3 at&t unlock problem Selected port: COM12 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: SAMSUNG-SGH-I747 Android version: 4.4.2 Product code: SGH2I747MBBATT Phone version: I747UCUFNE4 PDA version: I747UCUFNE4 CSC version: Unknown IMEI: --------------1 Phone S/N: R31D10ZGS7A Checking Super user right... false Not supported version for auto root Done with Samsung Tool v.18.2 how to root & unlock |
10-20-2014, 15:18 | #4 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Canada
Member: 119464 Status: Offline Thanks Meter: 288 | try towelroot or follow this link Android 4.4.2 + Root for AT&T Galaxy S3 SGH-i747! [Stock Rooted ROM] | GalaxyS3Root.com BR |
10-20-2014, 16:47 | #5 (permalink) |
Member: 588837 Status: Offline Thanks Meter: 146 | now after rooting with kingo root Selected model: I747 Selected port: COM12 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: SAMSUNG-SGH-I747 Android version: 4.4.2 Product code: SGH2I747MBBATT Phone version: I747UCUFNE4 PDA version: I747UCUFNE4 CSC version: I747ATTFNE4 IMEI: =============== Phone S/N: R31D10ZGS7A Checking Super user right... false Not supported version for auto root Done with Samsung Tool v.18.2 how to unable super user |
10-20-2014, 18:23 | #6 (permalink) |
Freak Poster Join Date: Mar 2014 Location: United States
Member: 2146046 Status: Offline Thanks Meter: 62 | TowelRoot.com Install, Make it Ra1n - Easy 100% success Root for S3/S4 Once rooted, unlock will work. 4G network might break though so be prepared to restore NV Data |
10-20-2014, 18:45 | #7 (permalink) |
No Life Poster Join Date: Aug 2013 Location: Somewhere on earth
Member: 2014742 Status: Offline Thanks Meter: 167 | If you're unable to root it then you have to downgrade it to an earlier version of 4.4.2. Or downgrade the modem to a 4.1.1 version and change it back to a kitkat modem when done. |
10-20-2014, 19:01 | #8 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: morocco
Member: 587405 Status: Offline Sonork: 100.1681610 Thanks Meter: 151 | Quote:
Download above file and follow the instructions 1- root the phone with CF-Auto-Root-d2can-d2vl-sghi747m using odin 2- install recovery recovery-clockwork-touch-6.0.4.3-d2att using odin 3- update superUS with UPDATE-SuperSU-v2.02.zip from the SD card using the recovery clockwork (install zip from sd card) 4- After step 3 recovery will ask you to fix root so apply the fix . | |
01-08-2016, 12:28 | #9 (permalink) |
Freak Poster Join Date: Feb 2006 Location: india.coimbatore Age: 47
Member: 233492 Status: Offline Thanks Meter: 93 | REPAIR INSTRUCTIONS: Repair IMEI/Serial/BT/WiFi/Product Code: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Reboot phone. 4. Connect USB cable, install drivers if needed. 5. Select Samsung diagnostic port in port settings. 6. Press 'Reset MSL' button to deactivate security. 7. Wait till phone reboot. 8. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 9. Fill values what you need to repair. 10. Press 'Repair' button. Reset EFS, Disable Factory Mode: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. 5. If you have yellow table on your device screen, then press 'Disable Factory Mode' button. Wipe EFS/NVM: If you have 'IMEI null/null' or 'Phone baseband unknown' errors, Then you can try to repair this errors with this function. Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. To use 'Auto backup/restore QCN' function (recommended): Type *#0808# and select 'DM+MODEM+ADB'. Type *#9090# and select 'DM/DUN over HSIC'. Or you can disable this function and use ADB only. 4. Connect the phone to PC with USB cable, install drivers if needed. 5. Choose diagnostic port in port settings if 'Auto backup/restore QCN' is not skipped. 6. Press 'Wipe EFS/NVM' button. Operation: Repair Selected model: SGH-I747 Selected port: COM6 USB Serial Port, Software version: 20.5 Waiting ADB device... Please, allow USB debugging on phone... Please, allow USB debugging on phone... OK Reading phone info... Model: SAMSUNG-SGH-I747 Android version: 4.3 Product code: Phone version: PDA version: I747UCUEMJB CSC version: I747ATTEMJB CSC country code: USA CSC sales code: ATT HW version: Phone S/N: Modem board: RF cal date: IMEI: Initialization AT RIL... error Done with Samsung Tool v.20.5 |
