04-10-2017, 11:33 | #1 (permalink) |
No Life Poster Join Date: Jan 2015
Member: 2325887 Status: Offline Thanks Meter: 134 | i747m after flash dead 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SGH-I747M Software version: 27.7 File analysis... Ok Total file size: 0x59408CA0 (1428 Mb) Searching USB Flash interface... COM62 detected Setup connection... Ok Reading PIT from phone... Ok Sending aboot.mbn... Ok Sending sbl2.mbn... Ok Sending sbl3.mbn... Ok Sending rpm.mbn... Ok Sending tz.mbn... Ok Sending boot.img... Ok Sending recovery.img... Ok Sending system.img.ext4... Ok Sending cache.img.ext4... Ok Sending NON-HLOS.bin... Ok Flashing done (time - 00:13:48) Done with Samsung Tool PRO v.27.7 i need laste firmware need |
