08-22-2015, 08:33 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Pakistan Age: 36
Member: 158181 Status: Offline Thanks Meter: 113 | i747m Emergency .... i have i747m imei is ok butt phone is on emergency i already repair /change imei but still emergency here is detail REPAIR INSTRUCTIONS: Repair IMEI/Serial/BT/WiFi/Product Code: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Reboot phone. 4. Connect USB cable, install drivers if needed. 5. Select Samsung diagnostic port in port settings. 6. Press 'Reset MSL' button to deactivate security. 7. Wait till phone reboot. 8. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 9. Fill values what you need to repair. 10. Press 'Repair' button. Reset EFS, Disable Factory Mode: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. 5. If you have yellow table on your device screen, then press 'Disable Factory Mode' button. Wipe EFS/NVM: If you have 'IMEI null/null' or 'Phone baseband unknown' errors, Then you can try to repair this errors with this function. Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. To use 'Auto backup/restore QCN' function (recommended): Type *#0808# and select 'DM+MODEM+ADB'. Type *#9090# and select 'DM/DUN over HSIC'. Or you can disable this function and use ADB only. 4. Connect the phone to PC with USB cable, install drivers if needed. 5. Choose diagnostic port in port settings if 'Auto backup/restore QCN' is not skipped. 6. Press 'Wipe EFS/NVM' button. Operation: Repair Selected model: SGH-I747M Selected port: COM6 Z3X BOX Serial Port, Software version: 20.5 Waiting ADB device... OK Reading phone info... Model: SGH-I747M Android version: 4.3 Product code: Not Active Phone version: I747MVLUEMK5 PDA version: I747MVLUEMK5 CSC version: I747MOYAEMK5 CSC country code: Canada CSC sales code: RWC HW version: Phone S/N: R21C81PSFLP Modem board: MSM8960 RF cal date: NONE IMEI: 350987120094762 Initialization AT RIL... OK Bypass MSL... OK Rebooting phone... OK Repair done Done with Samsung Tool v.20.5 plz guide me that how can i clove y problem.. |
