11-11-2013, 22:02 | #1 (permalink) |
Major Poster Join Date: Dec 2011 Location: Sofia, Bulgaria
Member: 1705542 Status: Offline Thanks Meter: 10 | i8190 EFS backup request As the phone was flashed with wrong fw, from another revision, it was jtag repaired but that damaged somehow the EFS data. Obvious phone cant rebuild the files itself, thus I want to try rewrite with EFS from working phone. To read EFS dump follow next steps: Thanks to anybody respod in! Regards, dailor Last edited by dailor; 11-11-2013 at 22:06. Reason: wrong title |
The Following User Says Thank You to dailor For This Useful Post: |
11-17-2013, 19:41 | #2 (permalink) |
Member: 1705542 Status: Offline Thanks Meter: 10 | i8190 RF block fail My conclusion is some hw fault in RF block, as the phone didn't connect to network in WCDMA mode. Possible fault of RF transceiver or Antenna switch. Based on Samsung's service manual, solution is to reball, resolder these two chips. |
05-13-2014, 15:44 | #7 (permalink) |
Freak Poster Join Date: Jun 2012 Location: pakistan multan
Member: 1768715 Status: Offline Sonork: sunny21 Thanks Meter: 37 | i8190 efs problem need help when i write efs phone work fine after remove usb cable from pc signal lost not registered on network |
The Following User Says Thank You to sunny21 For This Useful Post: |
03-28-2015, 12:29 | #8 (permalink) |
Junior Member Join Date: Mar 2015
Member: 2370021 Status: Offline Thanks Meter: 1 | need help guys i have gt-i8190n and it seems to have a network signal but it says not registered to network emergency calls only. thanks.... |
The Following User Says Thank You to markmaaba For This Useful Post: |
09-22-2016, 12:12 | #9 (permalink) |
Junior Member Join Date: Dec 2008
Member: 927799 Status: Offline Sonork: tggg Thanks Meter: 1 | hello anybody can help me please i need EFS file for GT-S7272 i can't find it my phone is dead thank you |
The Following User Says Thank You to lpa_m For This Useful Post: |
