12-04-2014, 09:46 | #1 (permalink) |
Freak Poster Join Date: Apr 2004 Location: TURKEY/KAYSERİ Age: 45
Member: 60931 Status: Offline Thanks Meter: 26 | I8190 movi_write card_status:2 (12) start_blk:584368 ODİN MODE product name :gt-I8190 custom bınary download:no movi_write card_status:2 (12) start_blk:584368 system status: custom odin pit pda csc flash ok no patrnerlock dead ı8190 no recvoery menü |
12-11-2014, 18:04 | #4 (permalink) |
Member: 60931 Status: Offline Thanks Meter: 26 | i have a problem trying to flash a i8190, i can fla****, wipe out everithing but when i restart it its just like i do nothing, i try repartition and give me an error i try the full flash and it just say OK and when the phone start its just like before, the phone works, but you cant add new info because when you restart it the new info its gone this is the log when i flash the fullflash file Connect to device ... Device pit saved to xxx Write file ste_boot.bin ... Write file ste_boot1.img ... Write file ste_boot2.img ... Write file ipl.bin ... Write file modem.bin ... Write file ssgtest.img ... Write file normal.bin ... Write file normal2.bin ... Write file param.lfs ... Write file boot.img ... Write file recovery.img ... Write file system.img ... Write file userdata.img ... Write file cache.img ... Write file hidden.img ... Flash completedi try wiping from the recovery whit no luck its say format ok but its just dont format anything, try another recovery but just dont get flashed Time used : 3 min 47 s |
The Following User Says Thank You to cenk kamil For This Useful Post: |
12-11-2014, 18:09 | #6 (permalink) |
Member: 60931 Status: Offline Thanks Meter: 26 | I have a problem with gt-i8190. It has a gesture lock, which I've forgotten. So I thought I could wpie data/factory reset, but I cant't enter Recovery Mode. While flashing with ODIN, it seemed to work. Odin succeeded. But on S3 Mini Screen I got this error message: "movi-write card_status:2 ...." After Reboot, nothing changed. Phone boots up normally. Gesture lock is still there. Same happens if I flash a whole stock rom via ODIN. I tried this stock ROM: HOME_I8190XXAMG4_I8190OXAAMG4_1332988_REV00_user_l ow_ship.tar.md5 After flash, nothing changed. Maybe someone is willing to help? Thanks in advance |
12-11-2014, 18:14 | #7 (permalink) |
Member: 60931 Status: Offline Thanks Meter: 26 | I tried 5 different firmwares. Everytime I try to flash with Odin, it throws errors on the screen of the phone. Odin says success, but nothing changes after flash. |
11-04-2015, 16:10 | #10 (permalink) |
Junior Member Join Date: Aug 2009 Location: Taguig City, Philippines Age: 41
Member: 1102957 Status: Offline Thanks Meter: 2 | Hi guys just passing through... I actually experiencing the same issue with the same make and model of device... Im pretty sure it is not a hardware problem coz I've research and found almost the same issue but on a different samsung device... Here is the link so you can check it out as well... [HOW-TO] Unbrick your soft bricked Galaxy S … | Verizon Samsung Galaxy S III | XDA Forums I've tried almost all solution including flashing using heimdall which didn't solve the problem... I'm still searching for solutions and will get back here and post the info soon.. |
02-18-2016, 14:45 | #12 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Republic of Kosova Age: 54
Member: 189304 Status: Offline Sonork: 100.1614605 Thanks Meter: 40 | im having the same problem,had 2 units and iam quite sure its a virus,every time i try to clean with any android av device restarts,when runs in safe mode everything fine.its no way to flash or root etc... |
06-10-2017, 15:58 | #14 (permalink) |
Major Poster Join Date: Oct 2013
Member: 2038521 Status: Offline Thanks Meter: 3 | hahahahahhahahaa.......... really it can not be possible to recover.. no one could fix this problem .. its a hardware .. i think its emmc problem .. we should just ignore the problem ....wait for next customer hahahah.... dont mind please just kidding ... |
