Old 01-24-2013, 10:47   #1 (permalink)
g-zona's Avatar
Member: 80391
Sonork: 100.1601620
Thanks Meter: 53
I8190N unlock or root?
I see that 4.1.2 is not supported:
Selected model: I8190N
Selected port: COM4 Z3X Box Serial Port
Selected port speed: 115200
Searching Samsung modem... detected COM264
Reading phone info...
Software version: I8190NXXALL4/I8190NXXALL3/I8190NVFGALL2
IMEI: 355074050145xxx
Product code:
Done with Samsung Tool v.13.8
Model: GT-I8190N
Android version: 4.1.2
Product code: GT-I8190MBNVIP
Phone version: I8190NXXALL3
PDA version: I8190NXXALL4
CSC version: I8190NVFGALL2
IMEI: Unknown
Checking Super user right... false
Rooting phone, please wait... error
Not supported android version 4.1.2
Is there a way to root it manually. For I8190 there is pre rooted fw, but for I8190N there is no such fw...
Old 01-30-2013, 10:05   #2 (permalink)
Member: 61189
Hi,
Idem for me...
an idea ?
Old 01-31-2013, 00:16   #3 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 173,750
wait then root will be available.
Old 02-01-2013, 15:33   #4 (permalink)
Member: 5202
Thanks Meter: 7
We are waiting for I8910N root or unlock solution...
Old 02-02-2013, 08:16   #5 (permalink)
Member: 638539
Thanks Meter: 2
Originally Posted by zitoune83 View Post
Hi,
Idem for me...
an idea ?
So....It seems to work for me. Follow the exact procedure from here . Don't panic....I know that you have I8190N. Do it. But after you've written rooted firmware the phone give you some errors. Again, don't panic! Turn off and turn on in recovery mode (volume up + home + power on) to do wipe data / factory setings. At this point do what needs to be done to unlock described above (see link). After that, go to support area, download firmware from I8190N, open Odin 3.07 and writte PDA and CSC. That's all! I unlocked 10 pcs. with this procedure.
Old 02-02-2013, 08:24   #6 (permalink)
Member: 61189
Thx !! , I try and i say to you
Old 02-02-2013, 08:25   #7 (permalink)
Member: 61189
Old 04-12-2013, 12:52   #8 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
i8190 manual HERE
Old 04-16-2013, 11:55   #9 (permalink)
vodafoneserver's Avatar
Member: 617174
Sonork: 100.1622609
Thanks Meter: 574
Selected port: COM4 Z3X BOX Serial Port
Model: GT-I8190N
Product code: GT-I8190TANEVR
CSC version: Unknown
IMEI: Unknown
Checking Super user right... true
Reading data from phone... OK
Now connect phone to UART cable
Checking phone at COM4 OK
Bypass MSL... OK
Unlocking... OK
Unlock done
Codes set to 00000000
Done with Samsung Tool v.14.2
Old 05-14-2013, 22:42   #10 (permalink)
Member: 1688036
1 step: ROOT
At the beginning you need to root with that way:
[Root] step by step Manual i8190 (N,L,T,I) Galaxy S3 Mini
2 step: DEBUGGING
Always be sure you installed all drivers correct and enable in Settings - Applications - Unknown Source and in Development - USB Debugging.
3 step: SAMSUNG TOOL Z3X
Before you push UNLOCK, you have connected the mobile in USB mode. During the process you need to change to UART CABLE
Example:
Model: GT-I8190
Android version: 4.1.1
Product code: GT-I8190MBACNX
Phone version: I8190XXALJL
PDA version: I8190XXALJL
CSC version: I8190OXAALJL
IMEI: Unknown
Checking phone at COM7 OK
Bypass MSL... OK
Unlocking... OK
Unlock done
Done with Samsung Tool v.14.0
If phone asks for code enter 00000000
UNLOCK OK!
The Following User Says Thank You to loreday For This Useful Post:
Old 05-27-2013, 18:24   #11 (permalink)
Registered User
Member: 667789
good solution it's down for me thnk
Old 08-01-2013, 23:56   #12 (permalink)
Member: 883011
nice work
thx for you all
1st time succes
Old 05-07-2014, 12:21   #13 (permalink)
Member: 710535
Selected port: COM12 Z3X BOX Serial Port
Searching Samsung modem... detected COM50
Software version: I8190NXXAMG1/I8190NXXAMG1/I8190NO2UAMH1
IMEI: 358307055995762
Product code:
Done with Samsung Tool v.17.3
Searching ADB device... OK
Model: GT-I8190N
Product code: GT-I8190MBNO2U
Phone version: I8190NXXAMG1
PDA version: I8190NXXAMG1
CSC version: I8190NO2UAMH1
Phone S/N: R21D90N27DN
Checking phone at COM12 OK
Bypass MSL... OK
Unlocking... OK
Unlock done
Rebooting phone... OK
Old 05-07-2014, 12:22   #14 (permalink)
Member: 710535
Product code:
Model: GT-I8190N
Bypass MSL... OK
Unlocking... OK
Unlock done
Page generated in 0.33810 seconds with 7 queries
