06-27-2013, 13:20 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: <<heaven>> Age: 43
Member: 754364 Status: Offline Thanks Meter: 59 | i8910 omnia hd imei repair help.! i8910 omnia hd imei repair , What is the practical solution of how to tell a picture ? |
06-27-2013, 14:12 | #2 (permalink) |
Member: 754364 Status: Offline Thanks Meter: 59 | 1. Phone must be powered on. 2. Type *#7284# and choise phone usb. 3. Type *#197328640#, select: Common - Diag Config - USB diag. 4. Reboot phone. 5. Connect USB cable, install drivers. 6. Select diagnostic port in port settings. 7. Press "Repair" button. 8. In opened window fill fields what you need to repair. 9. Press "OK". driver sees and Pressing the button repair to break away from the driver to the What's the problem here in error bug |
06-27-2013, 14:42 | #3 (permalink) |
Member: 754364 Status: Offline Thanks Meter: 59 | Selected model: i8910 Selected port: COM23 SAMSUNG Mobile Modem Diagnostic Serial Port (WDM) Selected port speed: 115200 Reading phone info... no answer from phone Done with Samsung Tool v.14.9 |
06-27-2013, 15:33 | #4 (permalink) |
Member: 754364 Status: Offline Thanks Meter: 59 | Selected model: I8910 Selected port: COM7 SAMSUNG Mobile Modem Diagnostic Serial Port (WDM) Selected port speed: 115200 Reading phone info... Model: GT-I8910 Country code: Çë°¡¸® Cal date: 2009-05-28 Factory SW: I8910XXIE9 Unique number: 70450000621032 Memory phone: MD512256B(I8910)S Reading IMEI... fail Reading security... error Done with Samsung Tool v.14.9 Done with Samsung Tool v.14.9 |
