06-27-2011, 10:58 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,282 | i9000 Code: Count supported models - 236 Done with Samsung Tool ver 10.4 Searching Samsung USB Modem... Detected (COM40) Model: GT-I9000 SW: I9000XXJPY IMEI: 3xxxxxxxxxxxxx Done with Samsung Tool ver 10.4 Searching Samsung USB Modem... detected (COM40) Reading Phone Info... OK Model: GT-I9000 Country Code: OPENÇâ Cal Date: 2010-07-28 Factory SW: I9000XWJM3_OXXJM2 Unique Number: 79680000040499 Memory Phone: KB100D00WM(I9000) IMEI: 354xxxxxxxxxxxxx SW: I9000XWJS5/I9000OXXJS4/I9000XXJPY/I9000XWJS5 Product Code: GT-I9000HKDXFA Bypass MSL... Error, Flash Patched Firmware First Done with Samsung Tool ver 10.4 |
06-29-2011, 09:11 | #2 (permalink) |
Member: 328688 Status: Offline Thanks Meter: 2,282 | i cant flash it it give me this errore Count supported models - 236 Searching Samsung USB Modem... Detected (COM40) Model: GT-I9000 SW: I9000XXJPY IMEI: 354xxxxxxx Done with Samsung Tool ver 10.4 File analysis... OK Total File Size: 0x00C00000 Searching USB flash interface... not found Done with Samsung Tool ver 10.4 |
06-29-2011, 14:22 | #3 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,550 | Quote:
06-29-2011, 22:15 | #8 (permalink) |
No Life Poster Join Date: Sep 2010 Location: In trouble Age: 49
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | Actually it's vol+home+power, but it won't work at all on some sets, this option is disabled, and you have to use a jig adaptor that plugs into usb... Search galaxy s jig on google for more information. |
06-29-2011, 22:27 | #9 (permalink) | |
No Life Poster Join Date: Jun 2005 Location: Sahara Desert Age: 77
Member: 150570 Status: Offline Thanks Meter: 52 | Quote:
holding down the Volume Down button + the Home key button (the middle button). While holding these both buttons, you need to switch ON your device. And then connect cable If not working read this; http://androidadvices.com/fix-downlo...g-in-galaxy-s/ | |
06-29-2011, 22:29 | #10 (permalink) |
Cheater -Don't Deal with him- Join Date: Mar 2006 Location: ACCRA GHANA Age: 39
Member: 244250 Status: Offline Sonork: 100.160773 Thanks Meter: 196 | pls i have a problem with my samsung t959v after writing path file phone dead. now i have fix boot with with order box. now phone restart so i need file to fix my phone to work 100% pls i need help and file to use to flash my samsung t959v t-mobile. |
06-29-2011, 22:29 | #11 (permalink) |
06-29-2011, 23:11 | #13 (permalink) |
Banned Join Date: Jan 2011
Member: 1487701 Status: Offline Thanks Meter: 0 | I had a same problem but was able to flash. this is what I did. I put the phone in download mode via holding Vol down+ Home then power button. then plug it directly to PC not via z3x. Z3X detected the phone and flashed it. Please give it a try and let's see. thanks |
06-30-2011, 07:26 | #14 (permalink) |
Member: 244250 Status: Offline Sonork: 100.160773 Thanks Meter: 196 | which model did u use to flash it becus flash file is not in z3x support .my is samsung my is samsung t959v t-mobile so should i use t959 or i9000 ? |
06-30-2011, 20:40 | #15 (permalink) | |
Member: 1487701 Status: Offline Thanks Meter: 0 | please watch this video very closely Quote:
YouTube - ‪Unlock SAMSUNG GALAXY S I9000 with Z3XBOX Tutorial‬‏ all thanks goes to haxor133t | |
*Hot Upload Samsung Mobile Android Flash File I5500 - I9000 - I8330 * | el oudi walid | GSM Mobile Links | 0 | 06-13-2010 23:07 |
*Hot Upload Samsung Mobile Android Flash File I5500 - I9000 - I8330 * | el oudi walid | UST Pro II | 0 | 06-13-2010 23:04 |
I9000 OS Smart Phone with GPS & OS 6.1 & Bluetooth | IPMART | ipmart WebShop | 0 | 11-26-2009 06:20 |
samsung omniya i9000 unlock succsessful | ravindra64 | Power-Sim | 1 | 10-24-2009 12:55 |
