I9000 imei: 00000000000000/0 hello, after updating my phone I9000 galaxy, he has no IMEI: 00000000000000 / 0 Count supported models - 223 Searching Samsung USB interface ... detected (COM20) Model: GT-I9000 IMEI: 00000000000000 / 0 Done with 3G Samsung Tool ver 9.4 as the solution to repair imei? helppppppppppppp:(:( |
flash patched firmware than repair imei. after repair if any problem than flash only modem part from original flash files |
hello, thanks, what is the flash file patched firmware? |
go on support site i9000 section u can see flash patch modem which is we usual use for unlocking this model |
hello i have loaded the modem firmware patched, does not take the line is the result is always imei 0000000000. I followed the guide found on the forum but can not recognize the phone http://forum.gsmhosting.com/vbb/f453...g-z3x-1171000/ Count supported models - 223 Searching Android modem... detected (COM21) Read Phone Info Fail Done with Samsung 3G tool ver 9.4 Searching Android modem... detected (COM21) Read Phone Info Fail Done with Samsung 3G tool ver 9.4 Searching Android modem... detected (COM21) Read Phone Info Fail Done with Samsung 3G tool ver 9.4 Searching Android modem... detected (COM21) Read Phone Info Fail Done with Samsung 3G tool ver 9.4 |
z3x team dear blang any slution :( |
put phone in download mode and reflash it using ODIN... and after flashing retry flashing with patched modem and repair imei..... make sure you write the exact imei as written at the back of the phone... |
I9000 imei: 00000000000000/0 hello, after updating my phone I9000 galaxy, he has no IMEI: 00000000000000 / 0 Count supported models - 223 Searching Samsung USB interface ... detected (COM20) Model: GT-I9000 IMEI: 00000000000000 / 0 Done with 3G Samsung Tool ver 9.4 as the solution to repair imei? helppppppppppppp |
problem Quote:
i can't make unlock, i can't repair imei, i've tryed flashing with diffrent firmwares, with diffrent flashers, and after every flash, i tryed the flashing with patched for unlock modem, tryed unlock and imei repair, and still no imei... sometimes, after flashing, my phone have full signal and imei is ok... it can work for hours... but, when i try to make a call, my phone reboots... after power on, imei is gone... any solution? i have z3x,microbox and nspro (and, of course, odin flasher and flashes for i9000) |
I have the same problem: I have the same problem: Quote:
Code: Count supported models - 223 Code: Searching Samsung USB interface... Code: Searching Android modem... detected (COM10) |
need repair firts NVM to solve the problem |
I tried to repair, but i couldn't. I copied NVM from another working phone (standart and full) and when I wrote it on damaged one I got "Phone not repond". |
Same problem. I9000 Imei 000000....0. Android 2.2. Write I9000_XXJPK_modem_patched_Z3X.tar is ok: Quote:
Hi lads that might sound weird but i was busy with other phones and it looks like it fixed by itself after 30 mins .... looks like baseband is bit delayed after phone startup .... so if your imei is 000000 the just leave the phone on for 10-20 mins and check again unlock it u proably will get the code 00000 witch wont work first time but will do at second attemp and after that phone seemes to work OK ;) |
