Old 04-10-2011, 10:57   #1 (permalink)
xina's Avatar
Member: 441775
Thanks Meter: 19
I9000 imei: 00000000000000/0
hello, after updating my phone I9000 galaxy, he has no IMEI: 00000000000000 / 0
Count supported models - 223
Searching Samsung USB interface ... detected (COM20)
Model: GT-I9000
Done with 3G Samsung Tool ver 9.4
as the solution to repair imei? helppppppppppppp
Old 04-10-2011, 11:04   #2 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
Thanks Meter: 856
flash patched firmware than repair imei.
after repair if any problem than flash only modem part from original flash files
The Following User Says Thank You to deepakgarg For This Useful Post:
Old 04-10-2011, 12:31   #3 (permalink)
xina's Avatar
Member: 441775
Thanks Meter: 19
hello, thanks, what is the flash file patched firmware?
Old 04-10-2011, 12:35   #4 (permalink)
yousaf22us's Avatar
Member: 113943
Thanks Meter: 73
go on support site i9000 section u can see flash patch modem which is we usual use for unlocking this model
The Following User Says Thank You to yousaf22us For This Useful Post:
Old 04-11-2011, 16:11   #5 (permalink)
xina's Avatar
Member: 441775
Thanks Meter: 19
hello i have loaded the modem firmware patched, does not take the line is the result is always imei 0000000000.
I followed the guide found on the forum but can not recognize the phone
Unlock i9000 step by step using z3x
Searching Android modem... detected (COM21)
Read Phone Info Fail
Done with Samsung 3G tool ver 9.4
Old 04-14-2011, 12:33   #6 (permalink)
Member: 272796
Sonork: 1603232
Thanks Meter: 403
same problem with me also 100% same.................................
z3x team dear blang any slution
Old 04-14-2011, 12:36   #7 (permalink)
ryumahon's Avatar
Member: 4021
Thanks Meter: 780
put phone in download mode and reflash it using ODIN... and after flashing retry flashing with patched modem and repair imei..... make sure you write the exact imei as written at the back of the phone...
Old 05-12-2011, 17:38   #8 (permalink)
Member: 625409
Thanks Meter: 28
Model: GT-I9000
Old 05-20-2011, 13:00   #9 (permalink)
Member: 135599
Thanks Meter: 14
problem
i also have the same problema...
i can't make unlock, i can't repair imei, i've tryed flashing with diffrent firmwares, with diffrent flashers, and after every flash, i tryed the flashing with patched for unlock modem, tryed unlock and imei repair, and still no imei...
sometimes, after flashing, my phone have full signal and imei is ok... it can work for hours... but, when i try to make a call, my phone reboots... after power on, imei is gone...
any solution? i have z3x,microbox and nspro (and, of course, odin flasher and flashes for i9000)
Old 07-15-2011, 03:10   #10 (permalink)
h34d_hunt3r's Avatar
Member: 104632
Thanks Meter: 103
I have the same problem:
I read info:
Searching Samsung USB interface...  detected (COM10)
  Model: GT-I9000
  IMEI: 00000000000000/0
flashed with I9000_XXJPK_modem_patched_Z3X.tar (without extract it):
File analysis... OK
Total File Size: 0x00C00000
Searching USB flash interface... detected COM3
Opening Port... OK
Setup connection... OK
Reading PIT From Phone... OK
Sending modem.bin... OK
Tried to rewrite the original IMEI:
Searching Android modem...  detected (COM10)
In the last step it goes to 50% and then I got the error.
Old 07-15-2011, 06:35   #11 (permalink)
jmr
Member: 614683
Sonork: 100.1605379
Thanks Meter: 341
need repair firts NVM to solve the problem
The Following User Says Thank You to jmr For This Useful Post:
Old 07-15-2011, 16:42   #12 (permalink)
Member: 104632
Thanks Meter: 103
How can I repair NVM?
I tried to repair, but i couldn't. I copied NVM from another working phone (standart and full) and when I wrote it on damaged one I got "Phone not repond".
Old 07-29-2011, 09:43   #13 (permalink)
Member: 16789
Thanks Meter: 3
Same problem. I9000 Imei 000000....0. Android 2.2.
Write I9000_XXJPK_modem_patched_Z3X.tar is ok:
File analysis... OK
Searching USB Flash Interface... detected COM7
Opening Port... OK
Flashing Done (time - 00:00:03)
Done with Samsung Tool ver 10.6
Read info:
Searching Samsung USB Modem... Detected (COM158)
Model: GT-I9000
IMEI: 000000000000000
But Repaire error:
Searching Samsung USB Modem... detected (COM158)
Reading Phone Info... Error
Unlock also ok:
Starting ADB Server... OK
Checking ROOT... FALSE
Reading Phone Info... OK
Android Version: 2.2
Model: GT-I9000
PDA Version: I9000XWJPB
CSC Version: I9000SERJP1
Rooting Phones... OK
Restarting... OK
Checking ROOT... TRUE
Reading Codes... OK
Detected SHA1 Codes
Please Wait, Calculating Codes... OK (time - 00:01:02)
MCK: 86209314
NCK: 00000000 UNLOCKED
NSCK: 00000000 UNLOCKED
SPCK: 00000000 UNLOCKED
CPCK: 00000000 UNLOCKED
SIM: 00000000 UNLOCKED
Repaire imei not work.
Old 08-04-2011, 16:27   #14 (permalink)
Member: 25852
Thanks Meter: 29
Hi lads that might sound weird but i was busy with other phones and it looks like it fixed by itself after 30 mins .... looks like baseband is bit delayed after phone startup .... so if your imei is 000000 the just leave the phone on for 10-20 mins and check again unlock it u proably will get the code 00000 witch wont work first time but will do at second attemp and after that phone seemes to work OK
I neeeeed NCDS 2.0!!!! plzz!!!! ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 06-16-2011 10:59
winlock 1.0 Aldrin Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 01-25-2000 04:49
Universal SP Unlocker 4.0 - home page !!! bp.bonus GSM Mobile Links 0 01-22-2000 22:31
download Datasuite 3.0 zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 10-31-1999 01:35
Page generated in 0.41057 seconds with 8 queries
