Old 10-09-2012, 19:49   #1 (permalink)
Member: 362622
Thanks Meter: 43
i9000 repair imei impossible
dears
please i want to repair the imei but without success
i tested with the last version ...efs checked uncheked..
i9000 2.3.6 rooted
can someone help me please
thanks
Done with Samsung Tool ver 11.1
Starting ADB Server...
OK
Checking ROOT... TRUE
Checking EFS... Present
Rebooting... OK
Waiting For Reboot Finish... OK
Rooting Phones... OK
Checking NV Data... Not Exist
Writing NV Data To Phone... OK
Searching Samsung USB Modem... Not Found
Old 10-09-2012, 20:58   #2 (permalink)
Member: 435455
100% solution
Originally Posted by amazir View Post
dears
i9000 2.3.6 rooted
thanks
OK
Rebooting... OK
use Samsung tool 12.7 it will work for you.
If in case doesn't work then downgrade it to 2.3.3 or 2.3.4 then 100% you can change imei. Then you can upgrade to any version.
Jalees
Old 10-10-2012, 08:34   #3 (permalink)
tahribat's Avatar
Member: 440574
Sonork: 100.1621371
Thanks Meter: 34
Please use latest Samsung tool and post result
Wbr
Old 10-12-2012, 11:41   #4 (permalink)
Member: 362622
Thanks Meter: 43
thanks bro
i tested both versions 11.1 and 12.7
downgraded to 2.3.3 and same result
Count supported models - 319
Android Version:
2.3.3
Model: GT-I9000
Product Code: Unknown
Phone Version: Unknown
PDA Version: I9000XWJVI
CSC Version: I9000DBTJV2
IMEI: Unknown
Reading Data From Phone... OK
Rebooting Phone... OK
Done with Samsung Tool ver 12.7
problem with usb modem
thanks
Old 10-12-2012, 12:22   #5 (permalink)
Crazy Poster
Member: 652864
Thanks Meter: 6
1. First turn on phone and write *#7284#
2. Select MODEM next write *#9090# and select USB DIAG
If *#9090# code not work - then :
- *#1575#
- Menu ---> Back --->[4] DIAG CONFIG --->[1] USB
- NO NEED UART CABLE
3. Conect phone to cable usb in z3x select diagnostic port comport and speed usb
4. Reboot phone Select UNLOCK/IMEI and press Factory Mode
Old 10-15-2012, 12:38   #6 (permalink)
Member: 362622
Thanks Meter: 43
thanks bro
with *#7284# ok
but with *#9090# and *#1575# code not work i have a message on phone Right-hardkey : back. please use the menukey.
when i type back nothing just blackscreen.
i tested also *#197328640#
thanks for your help
Old 10-15-2012, 13:12   #7 (permalink)
ms phone's Avatar
Member: 1119242
Sonork: 100.1638541
Thanks Meter: 121
thanks bro
with *#7284# ok
type *#1234# call
when show PHONE :unkown
use JTAG tool write full dump
The Following User Says Thank You to ms phone For This Useful Post:
Old 01-03-2013, 19:55   #8 (permalink)
Kashif Khan's Avatar
Member: 88016
Thanks Meter: 320
Originally Posted by ms phone View Post
type *#1234# call
hi can you upload full dump file plz because all links are dead.
Old 01-03-2013, 21:54   #9 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 186,515
what link you need?
if you want repair imei use z3x-box. last version of samsung tool.
Old 03-12-2013, 23:18   #10 (permalink)
Member: 1534512
Thanks Meter: 3
I have a S5570 with imei corrupt, when I type * # 1234 #
appears
PDA: 5570XWKTN
PHONE: Unknown
CSC: S5570OXXKTB
when I type * # 7284 # shows
right-hardkey back please use the menu key
I have setool and z3x,
as I can make it work?
Old 03-12-2013, 23:45   #11 (permalink)
Member: 972745
Sonork: 100.1627715
Thanks Meter: 216
why not use the latest version works flawlessly
Old 03-12-2013, 23:53   #12 (permalink)
Member: 1534512
Thanks Meter: 3
of z3x? o setool? but as I connect?
Page generated in 0.22576 seconds with 8 queries
