Unlock Server
Old 02-01-2011, 20:57   #1 (permalink)
thehelmut's Avatar
Member: 45247
i9000 unable flash patched file for unlock
thats what i do :
( yellow digger is on the phone's sreen .Downloading...)
if i connect in download mode -> android driver is NOT shown in 3G tool
log:
Searching USB flash interface... not found
Done with Samsung 3G tool ver 9.3
Searching Android modem... not found
but : if i connect the phone in normal mode -> android-driver is shown in 3G tool
any idea how to patch/ unlock this phone ?
PS. i also tried to unlock with 3G tool 8.4 as written at the forum->error
please help !
Old 02-01-2011, 21:11   #2 (permalink)
danrachita's Avatar
Member: 428861
Sonork: 100.1619141
With phone on just load the patch file in phone section and press flash or update firmware.
Phone will restart himself in download mode will flash the file and will start normal again himself.
After the phone is complettly on just press read info or unlock.
BR.
The Following User Says Thank You to danrachita For This Useful Post:
Old 02-01-2011, 21:31   #3 (permalink)
thehelmut's Avatar
Member: 45247
thanks for your help.but not working too . see here my screenshot
Old 02-01-2011, 21:36   #4 (permalink)
Little_Master's Avatar
Member: 1205146
Sonork: 100.1601660
connect phone in normal mode
make sure usb debugging option is enabled
Download Android sdk
Extract this at the loacation c:\AndroidSDK
Connect phone to PC and Install Drivers
now go to Start > RUN > type cmd
go to this directrory  "  c:\AndroidSDK\tools   "
now type " adb reboot download "
Your phone will reboot and will go into bootmode :)
after that , just select z3x box port .. select patch file
and click update firmware
software will detect auto port ..
Should be fine..
otherwise ,
come on at team viewer..
i'll have a look for u
LITTLE MASTER
The Following 3 Users Say Thank You to Little_Master For This Useful Post:
Old 02-01-2011, 21:38   #5 (permalink)
danrachita's Avatar
Member: 428861
Sonork: 100.1619141
Did you follow this steps before unlock procedure?
BR.
Qualcom mode method (only usb):
1. Power on phone.
2. Enable debugging on: menu>application settings>development..
3. Connect cables and setup drivers.
4. Press Unlock SP button.
5. Note: Flash patched modem first.
Old 02-01-2011, 22:03   #6 (permalink)
thehelmut's Avatar
Member: 45247
BR.
1. Power on phone.
yes i did . big thanks
The Following User Says Thank You to thehelmut For This Useful Post:
Old 02-01-2011, 22:04   #7 (permalink)
thehelmut's Avatar
Member: 45247
Your phone will reboot and will go into bootmode [/CODE]
Should be fine ...
LITTLE MASTER
you made my day :
Bypass MSL... OK
Reading Security... OK
Calculating codes... OK (time - 00:00:00)
Freeze code: 00000000
NET lock: 00000000
Sub lock: 00000000
SP lock: 00000000
CP lock: 00000000
For check lock status: *#7465625#
Searching Android modem... detected (COM8)
Read Phone Info Fail
if i typed in 00000000 an error occured but phone seems to be unlocked after restart .
thank you very much !!!
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 7 07-18-2012 07:57
needed pinout for carkit(N61xx) mobileinfo Nokia Hardware & Hardware-Repair Area 1 12-27-2006 10:20
Operator-Logo for 5110 MiMiR the WiseMan Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 06-25-1999 15:50
vBulletin Optimisation provided by vB Optimise v2.5.2 (Lite) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. ()
Page generated in 0.45998 seconds with 10 queries
