I9001 No network Hi, tell me if its posible this: I unlocked one Samsung I9001 with z3x and the phone can´t get any network. Then I did flashed with 2.3.6 firmware (I9001XXKPU_I9001OXAKP1) and unlocked again (i was no necesary but i read something about it), I made a factory reset and the phone is still with no network. My question is if this problem was because I use z3x or if the phone was wrong before i did unlocked? Thank |
Did you check phone before unlock? |
Yes, I did check the phone made calls and i say yes because i see the customer recived a call when I was talkin to her. |
I need NVM i9001 read Z3X or EFS read kTool, it should help to recover a network. |
reflash again (i9001XXKPU_XXKPH_OXAKP1) rom 2.3.6 with sam tool v 12.0 after this make new direct unlock br |
and the flash you mention is not the same that i did flashed? (i9001XXKPU_XXKPH_OXAKP1=I9001XXKPU_I9001OXAKP1) tHANK |
after try all these solution if your porblem does not solved then try this http://forum.gsmhosting.com/vbb/f453...-step-1384904/ root your device as shown in this thread then open samsung tool and click root unlock br saqib iqbal |
thk |
Please people from Z3x, correct this bug in 12.1 version Thank You |
Just fixed unlocking again with 12.2 Wbr |
Blackberry 9380 sos cum sim earror solution! Quote:
As devise get start up its running normal but with in some some times its sowing sos / sim error.. Kindly support me to solve the same. I am learning so many things for ur source... Thanking you. |
