Old 02-13-2012, 09:46   #1 (permalink)
Member: 165059
Thanks Meter: 23
I9001 No network
Hi,
tell me if its posible this:
I unlocked one Samsung I9001 with z3x and the phone can´t get any network. Then I did flashed with 2.3.6 firmware (I9001XXKPU_I9001OXAKP1) and unlocked again (i was no necesary but i read something about it), I made a factory reset and the phone is still with no network.
My question is if this problem was because I use z3x or if the phone was wrong before i did unlocked?
Thank
Old 02-13-2012, 09:52   #2 (permalink)
piroxi's Avatar
Member: 1134315
Thanks Meter: 49
Did you check phone before unlock?
Old 02-13-2012, 10:01   #3 (permalink)
Member: 165059
Thanks Meter: 23
Yes, I did check the phone made calls and i say yes because i see the customer recived a call when I was talkin to her.
Old 02-13-2012, 10:43   #4 (permalink)
Member: 349343
Thanks Meter: 11
I need NVM i9001 read Z3X or EFS read kTool, it should help to recover a network.
Old 02-13-2012, 11:06   #5 (permalink)
mohA™'s Avatar
Member: 199405
Sonork: 100.1576571
Thanks Meter: 322
reflash again (i9001XXKPU_XXKPH_OXAKP1) rom 2.3.6 with sam tool v 12.0
after this make new direct unlock
br
The Following User Says Thank You to mohA™ For This Useful Post:
Old 02-13-2012, 11:11   #6 (permalink)
Member: 165059
Thanks Meter: 23
Free Online Storage & File Upload with FileServe
The Following User Says Thank You to AquilesLynott For This Useful Post:
Old 02-13-2012, 11:18   #7 (permalink)
Member: 349343
Thanks Meter: 11
br
To me has helped, thanks.
The Following User Says Thank You to turboxxx For This Useful Post:
Old 02-13-2012, 11:26   #8 (permalink)
Member: 165059
Thanks Meter: 23
br
you mean to reflash with multidownloader, because z3x can not flash
and the flash you mention is not the same that i did flashed?
(i9001XXKPU_XXKPH_OXAKP1=I9001XXKPU_I9001OXAKP1)
tHANK
Old 02-13-2012, 11:28   #9 (permalink)
unlock phones's Avatar
Member: 1552610
Sonork: 100.1604734
Thanks Meter: 1,276
after try all these solution if your porblem does not solved then try this
Samsung i9100 Unlock procedure step by step
root your device as shown in this thread then open samsung tool and click root unlock
br
saqib iqbal
Old 02-13-2012, 11:42   #10 (permalink)
Member: 165059
Thanks Meter: 23
br
saqib iqbal
Sorry, but we are talking about I9001 not I9100, so if you dont give me an insecure kernell for this model i can not root the phone in the same way
thk
Old 02-13-2012, 11:48   #11 (permalink)
Member: 165059
Thanks Meter: 23
br
Bingo, you are right. I did flash again (with the same flash i used before) and made unlock with Samsungtool 12.0 and works perfect.
Please people from Z3x, correct this bug in 12.1 version
Thank You
Old 04-10-2012, 14:49   #12 (permalink)
Uvedovle's Avatar
Member: 10905
Thanks Meter: 109
Just fixed unlocking again with 12.2
Wbr
Old 12-30-2014, 17:31   #13 (permalink)
Member: 887422
Blackberry 9380 sos cum sim earror solution!
Originally Posted by uvedovle View Post
just fixed unlocking again with 12.2
wbr
i need blackberry 9380 sos cum sim earror solution! I make a jumpper but still it has some problems..
As devise get start up its running normal but with in some some times its sowing sos / sim error..
Kindly support me to solve the same.
I am learning so many things for ur source...
Thanking you.
6150 Network problem, please HELP! ZF Nokia Hardware & Hardware Repair 4 07-06-2004 18:07
5110/6110 after unlocking see only network to which it was locked and ... 2M Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 07-25-2000 00:51
6150 no outgoing calls edis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-20-2000 20:19
How do I remove a network provider lock? james.bond007 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 03-02-2000 21:59
no one can unlock 6110 05.40 25-5-99 fondas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 09-22-1999 08:03
Page generated in 0.39744 seconds with 8 queries
