Old 03-25-2013, 10:10   #1 (permalink)
That'sme's Avatar
Member: 228871
Thanks Meter: 43
I9001 problem
I am unable to connect the set with z3x software (cannot read the set)
The drivers are working perfectly on XP.
Tried with instructions given in help
only *#7284# work i select Modem but cannot connect the software
Other codes does not shows the hidden menus.
tried on 13.8,13.9,14.1,14.2 but all in vain......
Experts help needed ...
Regards
Old 03-25-2013, 10:25   #2 (permalink)
Member: 1873806
Sonork: 100:1637805
Thanks Meter: 6
*#7284# - USB PDA
*#9090# - USB Debug
Settings - Developer parametres- USB Debugging for android 4
Settings - Application - USB Debugging for android 2-3
device Manager on PC: be displayed as Samsung I9001 USB Android Composite Device
I understand that the phone is on Android. Driver ADB Android must also be installed
Old 03-25-2013, 10:28   #3 (permalink)
.::EXTREME::.'s Avatar
Member: 1619462
Sonork: 100.1606509
Thanks Meter: 1,483
micro-uart cable:
1. Phone must be powered on.
2. Connect the phone to UART port.
3. Choose correct COM port in port settings
4. Press "Read info" button.
micro-USB cable:
2. Type *#7284# and choise phone usb.
3. Type *#197328640#, select: Common - Diag Config - USB diag.
4. Reboot phone.
5. Connect USB cable, install drivers.
6. Select diagnostic port in port settings.
7. Press "Read info" button.
Old 03-25-2013, 11:14   #4 (permalink)
That'sme's Avatar
Member: 228871
Thanks Meter: 43
Originally Posted by .::EXTREME::. View Post
micro-uart cable:
micro-USB cable:
4. Reboot phone.
*#197328640# then screen hows nothing (no menu: select: Common - Diag Config - USB diag.)
z3x micro uart service port no info displayed....
Old 03-25-2013, 15:21   #5 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,131
that'sme
Contact Me Pm.
BR.
Arsalan gsm2000.
Old 03-26-2013, 08:11   #6 (permalink)
That'sme's Avatar
Member: 228871
Thanks Meter: 43
Originally Posted by halik-85 View Post
*#7284# - USB PDA
*#9090# - USB Debug
*#7284# - USB PDA works ok
But *#9090# - USB Debug not work (no option Visible)??????
USB Debugging ok
Device all ok detected and installed (ADB and Composite both)..
Old 03-26-2013, 09:13   #7 (permalink)
Member: 1873806
Sonork: 100:1637805
Thanks Meter: 6
Yes, this parametres must be visible! This code working for android, if no option Visible (it happens), then only select USB Debug in settings
Old 03-26-2013, 12:35   #8 (permalink)
That'sme's Avatar
Member: 228871
Thanks Meter: 43
usb debug in setting done but unable to read or perform any operation on z3x using usb????
Old 03-29-2013, 09:33   #9 (permalink)
That'sme's Avatar
Member: 228871
Thanks Meter: 43
I flashed the set with odin and upgraded from 2.3.3 to 2.3.6 and root the set also but unable to perform any function ( read , unlock, repair nothing )
with z3x can somebody help me with it
Regards
Old 03-29-2013, 09:38   #10 (permalink)
cycofcgb's Avatar
Member: 1388004
Sonork: 100.1637034
Thanks Meter: 438
Are you sure that adb drivers are well installed ?
Old 03-29-2013, 09:42   #11 (permalink)
That'sme's Avatar
Member: 228871
Thanks Meter: 43
all drivers install perfectly.
Old 03-29-2013, 09:54   #12 (permalink)
cycofcgb's Avatar
Member: 1388004
Sonork: 100.1637034
Thanks Meter: 438
so your phone appears like that :
Old 03-29-2013, 10:00   #13 (permalink)
That'sme's Avatar
Member: 228871
Thanks Meter: 43
yes device manager ok ..
Old 03-29-2013, 13:08   #14 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 173,198
*#7284#, try here choise modem.
restart phone. try do any job.
Page generated in 0.33286 seconds with 7 queries
