05-17-2012, 09:45 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: spain
Member: 1038811 Status: Offline Sonork: 100.1585462 Thanks Meter: 974 | i9003 flashing error, samsung logo loop. Code: Count supported models - 305 File analysis... OK Total File Size: 0x158F2800 Searching USB Flash Interface... detected COM98 Opening Port... OK Setup connection... OK Reading PIT From Phone... OK Sending boot.bin... OK Sending sbl.bin... OK Sending param.lfs... OK Sending normalboot.img... OK Sending boot.bin... OK Sending sbl.bin... OK Sending param.lfs... OK Sending system.rfs... OK Sending cache.rfs... OK Sending userdata.rfs... OK Sending modem.bin... OK Sending cache.rfs... OK Flashing Done (time - 00:01:26) Done with Samsung Tool ver 12.4 File analysis... OK Total File Size: 0x158F2800 Searching USB Flash Interface... detected COM98 Opening Port... OK Setup connection... OK Set PIT File... Error Done with Samsung Tool ver 12.4 Phone Not Found Done with Samsung Tool ver 12.4 File not exists Done with Samsung Tool ver 12.4 File analysis... OK Total File Size: 0x158F2800 Searching USB Flash Interface... detected COM98 Opening Port... OK Setup connection... OK Set PIT File... Error Done with Samsung Tool ver 12.4 Phone Not Found Done with Samsung Tool ver 12.4 File analysis... OK Total File Size: 0x158F2800 Searching USB Flash Interface... detected COM98 Opening Port... OK Setup connection... Error Done with Samsung Tool ver 12.4 Phone Not Found Done with Samsung Tool ver 12.4 File analysis... OK Total File Size: 0x158F2800 Searching USB Flash Interface... detected COM98 Opening Port... OK Setup connection... OK Set PIT File... Error Done with Samsung Tool ver 12.4 File analysis... OK Total File Size: 0x158F2800 Searching USB Flash Interface... detected COM98 Opening Port... OK Setup connection... OK Reading PIT From Phone... OK Sending boot.bin... OK Sending sbl.bin... OK Sending param.lfs... OK Sending normalboot.img... OK Sending boot.bin... OK Sending sbl.bin... OK Sending param.lfs... OK Sending system.rfs... OK Sending cache.rfs... OK Sending userdata.rfs... OK Sending modem.bin... OK Sending cache.rfs... OK Flashing Done (time - 00:01:27) Done with Samsung Tool ver 12.4 File analysis... OK Total File Size: 0x158F2800 Searching USB Flash Interface... detected COM98 Opening Port... OK Setup connection... OK Reading PIT From Phone... OK Sending boot.bin... OK Sending sbl.bin... OK Sending param.lfs... OK Sending normalboot.img... OK Sending boot.bin... OK Sending sbl.bin... OK Sending param.lfs... OK Sending system.rfs... OK Sending cache.rfs... OK Sending userdata.rfs... OK Sending modem.bin... OK Sending cache.rfs... OK Flashing Done (time - 00:01:28) Done with Samsung Tool ver 12.4 http://img834.imageshack.us/img834/3...7244027385.jpg |
05-17-2012, 09:55 | #2 (permalink) |
No Life Poster Join Date: Feb 2012 Location: Romania Age: 41
Member: 1722871 Status: Offline Thanks Meter: 116 | If you will use search function it will help you to understand that is an Hardware problem with I9003. It is an memmory fault and no way to resolve it with software. Only mainboard replace and somebody say if you rehot the IC memory it will work, if I understand it corectly. I dont know how is done |
05-17-2012, 10:34 | #3 (permalink) |
Member: 1038811 Status: Offline Sonork: 100.1585462 Thanks Meter: 974 | Thanks, I search a lot. I even saw the post about taking the memory chip out and using sd card as primary memory I got it working using riff, so I am not noob I will research again a little bit because it looks like flashing problem, I got some problem with riff and did it the hard way. Maybe that is the origin of all this mess. Maybe I should redo riff procedure. Enviado desde mi A100 |
05-17-2012, 11:35 | #4 (permalink) | |
Member: 1722871 Status: Offline Thanks Meter: 116 | Quote:
I read that even with Riff, other users didnt succeed to make the phone working. I'm waiting now for three weeks for my Riff box. So I know verry little about Riff power | |
05-17-2012, 13:02 | #5 (permalink) |
Member: 1038811 Status: Offline Sonork: 100.1585462 Thanks Meter: 974 | It was completely dead after user tried to flash it. I revived using riff, got download mode and flashed with 2.3.4 firmware. But I always git that boring message about no directory and wipe data failed. Tried with some other flashes and in the end posted here so that I can get some other perspective and suggestion to do that i might have forgot to do. Enviado desde mi A100 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
Phone Stuff for FREE & KEy-GEn For Logo Editor ! | BoNtEk - ThA WtC MeMbA | Nokia Multimedia | 8 | 10-31-2012 20:17 |
Operator-Logo for 5110 | MiMiR the WiseMan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-25-1999 15:50 |
