Old 03-28-2012, 09:46   #1 (permalink)
Member: 1679236
Sonork: Prohibited
Thanks Meter: 45
I9003 Restart Problem After Update
Hi,
I Recieved Phone From Customer In Restart Problem Which Was Interrupt During Update And After Update Phone Continuously Restart .I Flashed Phone With Many Firmwares Phone Flashed Successfully But Phone Is In Same Problem.I Flashed With Odin Flasher.If Any One Have Any Suggestion Or Solution ,Then Please Post Here.
Br,
..::ALI::..
The Following User Says Thank You to ..::ALI::.. For This Useful Post:
Old 03-28-2012, 09:53   #2 (permalink)
Gsm Mardan's Avatar
Member: 897494
Sonork: 100.1581481
Thanks Meter: 1,102
Check ur phone imei and baseband and post Result
Old 03-28-2012, 09:54   #3 (permalink)
StRaNgE PeRsOn's Avatar
Member: 391445
Sonork: 100.1583575
Thanks Meter: 388
please check the phone recovery if it says mmc mount failed in red letters?
i received a phone with same problem I9001 and found that it was a hardware fault due to the SD CARD was unable to mount at startup so was restarting at Samsung Logo,
the other reason could be the damaged baseband
please give info from the Recovery
Thanks and regards
The Following User Says Thank You to StRaNgE PeRsOn For This Useful Post:
Old 03-28-2012, 09:54   #4 (permalink)
cycofcgb's Avatar
Member: 1388004
Sonork: 100.1637034
Thanks Meter: 438
Post screenshot and/or logs of your flashing tries
Old 03-28-2012, 09:56   #5 (permalink)
abidottupara35's Avatar
Member: 1178222
Sonork: 100.1602620
Thanks Meter: 466
Originally Posted by ..::ALI::.. View Post
Hi,
Br,
..::ALI::..
bro i have too many problume like this
i find solution this is not software problume is this hw (eMMc) corrupted
http://forum.gsmhosting.com/vbb/f200...-logo-1411904/
Old 03-28-2012, 09:58   #6 (permalink)
mohit_kripalu01's Avatar
Member: 486357
Sonork: 100.1602846
Thanks Meter: 1,196
Maybe this one can help
= download Check Fus Downloader 2.1
= run & choose ANDROID/i9003
= choose what REGION you want to download
= then click CHECK Firmware & click DOWNLOAD
= wait to FINISH Download
= extract compressed file [ zip/rar ]
= flash the phone thru ODIN
i'm sure that you have a damaged emmc ....can't mount or format and this stop your phone to boot .... the only solution is to flash a custom kernel like ClockworkMod Recovery 5.0.2.6
http://www.multiupload.com/W2XK4IOWSP
Open Odin
Choose "GT-I9003_CWM_5.0.2.6.tar" as PDA
Boot your Device into Download Mode (Vol Down + Home + Power)
Connect your Device via USB
Hit "Start" Button
Flash the phone with a modded firmware from sdcard ....but the internal memory will not work ......
https://rapidshare.com/#!download|46...AD680163C6|0|0
Reboot into Recovery
Install the ROM from sdcard using ClockworkMod Recovery
many time i9003 restart problem hardware
The Following User Says Thank You to mohit_kripalu01 For This Useful Post:
Old 03-28-2012, 10:18   #7 (permalink)
Member: 1679236
Sonork: Prohibited
Thanks Meter: 45
Open Odin
Hit "Start" Button
https://rapidshare.com/#!download|465p2|3198315351|update-cm-7.1.0-GalaxySL-KANG-signed.zip|107107|R~A93A808C05FD67B2B9C65EAD680163 C6|0|0
I Will Try And Post Here Results.Multiupload link is not working.
Br,
..::ALI::..
Old 06-20-2012, 12:57   #8 (permalink)
Member: 29652
Thanks Meter: 43
did u solve ur problem with this soluion
Old 06-21-2012, 21:29   #9 (permalink)
Member: 1670609
Sonork: 1591361
Thanks Meter: 8
TW RTU I SFVETwett246208723r454re4f
Old 07-06-2012, 08:30   #10 (permalink)
Member: 219917
Thanks Meter: 60
Hello Ali!
Did you repair phone this phone?
Old 07-06-2012, 10:35   #11 (permalink)
Member: 219917
Thanks Meter: 60
Strange. My phone start with this CM7 flash file, but internal memory is... 1.5 GB instead of 4GB.
CPU is warm, but phone is working. I can mount in recovery EMMC and uSD. Have no idea what is wrong with this phone.
6150 Lock Problem Zeljko Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 10-16-2013 08:16
GId1 problem old_man Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-18-2006 15:21
6110 5.47 sw unlock problem gsms Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-21-1999 18:43
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Page generated in 0.36574 seconds with 8 queries
