06-18-2013, 16:20 | #1 (permalink) |
No Life Poster Join Date: Jan 2007 Location: mumbai india
Member: 432679 Status: Offline Thanks Meter: 118 | i9100 imei change error..ver 4.1.2 kindly assit Selected model: I9100 Selected port: COM5 Z3X BOX Serial Port Selected port speed: 115200 Searching Samsung modem... detected COM153 Reading phone info... Software version: I9100XWLST/I9100DDLS9/I9100ODDLSE IMEI: 004999010640000 Done with Samsung Tool v.14.7 Selected model: I9100 Selected port: COM5 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: GT-I9100 Android version: 4.1.2 Product code: Not Active Phone version: I9100DDLS9 PDA version: I9100XWLST CSC version: I9100ODDLSE IMEI: Unknown Checking Super user right... true Writing EFS to phone... OK Rebooting phone... OK Searching Samsung modem... detected COM153 Waiting while modem will be ready... No answer from phone Done with Samsung Tool v.14.7 |
06-18-2013, 17:49 | #4 (permalink) |
Registered User Join Date: Apr 2008 Location: sadiqsajan
Member: 759011 Status: Offline Sonork: 164643 (server.sonork.com Thanks Meter: 152 | i9100 imei change error..ver 4.1.2 Octopus Box USE NOT CHAING IMEI Z3X ALREDY 5 TIME TRY BUT NOT CHANG ALREDY I9300 IMEI NULL GIVE ME IDYA BUT 1 DAY TRY URLT CABLE BOX CABLE USB BUT NOT CHING |
06-18-2013, 18:03 | #5 (permalink) |
Member: 432679 Status: Offline Thanks Meter: 118 | now when feed og imei same issue were can i find patch file its not there in support side can i downgrade the set and try kindly suggest downgrade procedure |
06-18-2013, 21:10 | #6 (permalink) |
Junior Member Join Date: Apr 2012
Member: 1752659 Status: Offline Thanks Meter: 1 | Downgrade phone to 4.1.1 or even ICS. I cannot change IMEI on any samsung phone running 4.1.2 or higher. Switch to 4.1.1 or lower and it works. Also make sure it does not have a custom rom as that also causes problems. |
The Following User Says Thank You to manteca For This Useful Post: |
06-19-2013, 05:20 | #8 (permalink) |
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,469 | Select port(z3x box) repair option change to usb to com then run repair option no need to repair efs just repair imei |
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post: |
06-19-2013, 07:37 | #9 (permalink) |
Member: 432679 Status: Offline Thanks Meter: 118 | tried not happeing regards Selected model: I9100 Selected port: COM5 Z3X BOX Serial Port Selected port speed: 115200 Searching Samsung modem... detected COM153 Reading phone info... Software version: I9100XWLST/I9100DDLS9/I9100ODDLSE IMEI: 004999010640000 Done with Samsung Tool v.14.7 Selected model: I9100 Selected port: COM5 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: GT-I9100 Android version: 4.1.2 Product code: Not Active Phone version: I9100DDLS9 PDA version: I9100XWLST CSC version: I9100ODDLSE IMEI: Unknown Checking Super user right... true Reading data from phone... OK Writing data to phone... OK Rebooting phone... OK Checking phone at COM5 No answer from phone Done with Samsung Tool v.14.7 |
06-19-2013, 08:47 | #12 (permalink) |
No Life Poster Join Date: May 2005 Location: CellcomEngineering Age: 42
Member: 147116 Status: Offline Sonork: 100.1578260 Thanks Meter: 316 | flash it 2.3.6 then change imei then update 4.1.2 work 100000000%.. |
The Following User Says Thank You to shohag For This Useful Post: |
06-19-2013, 09:18 | #13 (permalink) |
Member: 432679 Status: Offline Thanks Meter: 118 | bro its mean downbgrading is it possible coz same model i downgrade 6 month back after which cell keep on restarting kindly suggest how to downgrade regards! |
06-19-2013, 13:17 | #15 (permalink) | |
Member: 147116 Status: Offline Sonork: 100.1578260 Thanks Meter: 316 | Quote:
z3x can repair or change imei firmware version 2.3.6 then u can update on any new firmware | |
