02-02-2013, 06:44 | #1 (permalink) |
No Life Poster Join Date: Jan 2009
Member: 946381 Status: Offline Thanks Meter: 150 | I9100 SIGNAL PROBLEM-imei and baseband ok-help me to write dump http://forum.gsmhosting.com/vbb/f777...000-a-1600447/ lash stock rom 4.0.3 or 4.0.4 with odin 1.85 make sure you use home tar.md5 which include all part in 1 file. recommended "I9100XWLPW_I9100ODDLPC_I9100DDLPB_HOME.tar.md 5" write attached efs backup with tool write dump option in z3x. restart device few time you have 0044 imei its normal. repair imei with uart c3303k cable on z3x by tick on com port at repair option. wait for network 2 min to 5min first time. post results. make sure you did exactly same order as i posted. ps: all user must note this attached efs only for I9100 NOT T NOT P ps2: all user must note that you do not need to root your self its automatic in repair tools because of "exynos-abuse" root exploit. but can not write dump in above by z3x is my problem. tried via usb and com-did not connect. helpppppppppppp |
