Old 05-31-2012, 01:30   #1 (permalink)
Member: 16943
Thanks Meter: 35
i9100 unknown imei
hi
i have one i9100 with unknown imei and baseband
i have try to repair imei and i have this log:
Searching Samsung USB Modem... Detected (COM91)
Model: GT-I9100
SW: ERROR
IMEI: 000000000000000
Done with Samsung Tool ver 12.5
Android Version: 2.3.3
Model: GT-I9100
Product Code: Unknown
Phone Version: Unknown
PDA Version: I9100BVKH1
CSC Version: I9100AMNKH1
IMEI: Unknown
Checking ROOT... FALSE
Rooting Phones, Please Wait... OK
Checking ROOT... TRUE
Reading Data From Phone... OK
Writing NV Data To Phone... OK
Rebooting Phone... OK
Searching Samsung USB Modem... Not Found
what can i do?
thanks
Old 05-31-2012, 15:19   #2 (permalink)
paulo pessoa's Avatar
Member: 1474113
Sonork: 100.1604217
Thanks Meter: 472
atualizaei after my i9100 had this error in odin would like information to reach a solution to this problem thank you all!
Old 05-31-2012, 15:48   #3 (permalink)
Member: 1605578
Sonork: 100.1615760
Thanks Meter: 13
hi brother repair your imei if z3x clic repair or microbox work in 100%
Old 05-31-2012, 16:44   #4 (permalink)
(Drity KING)-DK's Avatar
Member: 1004812
Thanks Meter: 152
1. Power on phone.
2. Enable debugging on: menu>application settings>development..
3. Connect cables and setup drivers.
4. Press Repair button.
5. Enter new IMEI and press OK
if it does not help to write the full flash file dump
Old 05-31-2012, 21:44   #5 (permalink)
Member: 150570
Thanks Meter: 52
Flash new FW to phone, use a version 2.3.5 >
[ROM+Guide]Official i9100 Firmwares LPE/Q/7/2/F/S/4/7/G/9/W/D/F Download - xda-developers
Install root manually.
Then use Z3X version 12.1 or 12.2. Some people have used the same version as you 12.4 and it worked > so, to try and change/reinstall imei > check Unlock root as well as EFS Repair. It will show error. don't remove cable or do anything. just click on Repair as soon as phone has finished booting up. And imei repair should go through successfully. I've only worked on 12.1 and this method works every time first time and not hours later, as is the case if you check 'search'
The Following User Says Thank You to Phoneze For This Useful Post:
Old 06-02-2012, 14:22   #6 (permalink)
Member: 1474113
Sonork: 100.1604217
Thanks Meter: 472
Friend has not resuldato positive can still help me?
Old 06-03-2012, 22:08   #7 (permalink)
Member: 150570
Thanks Meter: 52
Just keep trying, it will work eventually.
Old 06-06-2012, 01:19   #8 (permalink)
Member: 16943
Thanks Meter: 35
hi
some help for me?
i began the post and nobody answer me?
i did try to repair imei but not success, then i think i must flash the phone.
i don't know if i must flash with full flash file dump (what is this?, if posible to xdo it with z3x or do i need special machine?
can anybody explain me what files must i put in odin or another soft to flash the phone?
the origina lversion is from orange spain BVKH1 and i can't find it
can anybody helps me?
thanks
Old 02-05-2013, 05:32   #9 (permalink)
menshaoui's Avatar
Member: 1164285
Sonork: 100.1648187
Thanks Meter: 296
Originally Posted by jak2812 View Post
hi
Model: GT-I9100
SW: ERROR
Model: GT-I9100
IMEI: Unknown
what can i do?
thanks
no nedd repair imie or phone version just flash with original fermwar
good lack
Old 02-05-2013, 05:40   #10 (permalink)
menshaoui's Avatar
Member: 1164285
Sonork: 100.1648187
Thanks Meter: 296
no imie in desply no network coniction plaes flash with spt box your prb seliv
Working IMEI changed phone? Barjo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 03-01-2015 11:49
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
Nokia 51xx/61xx imei changer ver. 1.10?????? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 04-06-2012 16:22
6110 imei changer !!!!!! Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 11-21-2011 01:44
Page generated in 0.22735 seconds with 9 queries
