03-22-2015, 09:38 | #1 (permalink) |
No Life Poster Join Date: Sep 2013 Location: India
Member: 2030192 Status: Offline Thanks Meter: 1,334 | I9192 Flash failed need help details inside image size too large!! w:1090, h:1920 display image fail SECURE FAIL: Kernel i don't know previous version installed on mobile so i tried to flash this file "I9192XXUAMH2_SERAMF9" found on support without pit that give error!! Code: Selected model: I9192 Selected port: COM3 Easy Jtag Control Port Selected port speed: 115200 File analysis... OK Total file size: 0x5A3197AC Searching USB Flash Interface... detected COM11 Setup connection... OK Reading PIT from phone... OK Saved to C:\Program Files\Z3X\Samsung\SamsungTool\Pit\I9192_22-3-2015_13-51-57.pit Sending boot.img... OK Sending recovery.img... OK Sending sbl1.mbn... OK Sending sbl2.mbn... OK Sending sbl3.mbn... OK Sending aboot.mbn... Error Done with Samsung Tool v.18.8 Done with Samsung Tool v.18.8 if i want to flash with pit then which one to select there is two pit file on support "CSB_signed_SERRANODS_ONEPIT_OPEN_130523.pit" & "SERRANODS_EUR_OPEN.pit" and also for i9192 there is two version os available 4.2.2 and 4.4.2 which on to select on support are any other place pls need help |
03-23-2015, 07:21 | #9 (permalink) |
Member: 2030192 Status: Offline Thanks Meter: 1,334 | Finally Solved my problem:::: Thank you for the help brothers.. To Solve NO NEED 4 FLASH FILE NO NEED RE-PARTITION Just Flash With Single Flash file (((I9192XXUCNJ3_I9192SERCNJ3_I9192XXUCNJ3_HOME.tar ))) That's all problem will be solved And in my Case even User Date is still there For P.M Pls check on support i can't find which one file is 4.4.2 on I9192 And Also Big Need Is Pls Increase Download Speed For me Downloading 900 Mb Take Above 8 hours Customer's are in hurry |
